Author Topic: Kailh Box Red Pro switch  (Read 9137 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 26 August 2020, 05:56:20 »
Kailh Box Red Pro Switches
SMD LED compatible.
Pls, pay attention: Switch only, not including other things.
Great for those who are a bit messier at the keys, Kaihua’s Kailh Box switches are IP56 rated to keep dust and moisture out. Created with a box around the cross stem instead of the cross stem just sticking up, they’re built to avoid corrosion and debris buildup. The box extends to the contact plate and leaf, providing extra protection. Utilizing the already popular Cherry MX form, Kaihua Kailh switches provide an easy transition so you don’t have to let go of your existing keycap collection. The MX-compatible stems provide a secure fit for any keycaps, PCBs, or plates you might want to assemble.
Specs
Box Red Pro
Linear
Operating force: 35 gf (+/-10 gf)
Pretravel: 1.8 mm (+/- 0.3 mm)
Pressure point: 1.7 mm
Total travel: 3.6 mm (+/- 0.3 mm)
Reset point: 1.8 mm
PURCHAS HERE
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Kailh Box Red Pro switch
« Reply #1 on: Wed, 26 August 2020, 05:57:40 »
