Author Topic: PBT ISO keycaps for Dell AT102W?  (Read 4475 times)
Offline spremino
« on: Wed, 26 August 2020, 13:08:51 »
What PBT ISO keycaps are compatible with Dell AT102W? Are keycaps from Apple Extended I or II compatible? Thank you.
A long space bar... what a waste of space!
Offline Hak Foo
  • Make America Clicky Again!
Re: PBT ISO keycaps for Dell AT102W?
« Reply #1 on: Wed, 26 August 2020, 17:01:09 »
I think the AEK tends to have an unusually small ISO Enter.
You might look at the XDA profile blank set available on KPRepublic.  Note these require customized stabilizers/wires.
Overton130, Box Pale Blues.
Offline spremino
« Reply #2 on: Sun, 04 April 2021, 05:29:11 »
Sorry for my very late answer.
Yet square keys should fit, right?
I have looked at them. Did you mean that they may not be compatible? Or that then I should make my own stabilizers/wires?
Thank you.
« Last Edit: Sun, 04 April 2021, 16:20:40 by spremino »
