Author Topic: [IC] CLAP 65% Gasket Mount Keyboard  (Read 17291 times)
Offline BurganovAziz
« on: Sat, 29 August 2020, 23:08:03 »
Hello keyboard geeks, I'm Aziz from CLAP LAB. I have never imagined that one day I will be able to design my own keyboard and post on GH! Today I want to show you my 65% gasket mounted keyboard. As a 65 lover I got inspirations from keyboards such as: Rama m65, Iron165, Noah, Space65 and many others! Okay, enough of me talking, I want to show you some renders (please excuse my rendering skills :D)
Sep 1 Update:
I want to thank all of you for your time to write the feedbacks, they are so valuable to me! I made some changes according to them.
So here is the new version with the renders, hope it is better than the first version.
Sep 3 Update:
250864-0
250866-1
250868-2
250870-3
250872-4
250874-5
250876-6
250878-7
250880-8
250882-9
Technical Info:
1. 7 Degree angle
2. Gasket Mount
3. 6061 Aluminium anodized
4. PCB-QMK supported Hotswap and Solder
5. USB Type C
What has been done:
The prototypes are coming soon As you all have suggested, the prototypes are postponed for the final deisgn
The PCB has been designed and tested, prototypes coming soon The pcb is not expensive comparing to CNC a case so the new PCB is under designing.
What needs to be done:
Test the assembly
Test the PCB
DISCORD: https://discord.gg/7nsJJKV I'm new to Discord so if there is something wrong with it please tell me!
Here is the IC from, please feel free to fill it out!
https://docs.google.com/forms/d/e/1FAIpQLSdCJrBWmtmrOFJnK3ehEHuY7i5-9L_7lgeMwopCfGX3fnU-NA/viewform?usp=pp_url
« Last Edit: Wed, 02 September 2020, 22:57:52 by BurganovAziz »
Offline nu_types
  • Formerly Iredeus
Re: [IC] CLAP 65% Gasket Mount Keyboard
« Reply #1 on: Sat, 29 August 2020, 23:12:13 »
This board makes me feel itchy
Offline yoot
    • none
« Reply #2 on: Sat, 29 August 2020, 23:12:41 »
Looks really tall. What's it's front height?
Offline IOVERCALLHISTIOCYTES
« Reply #3 on: Sat, 29 August 2020, 23:19:33 »
Can't wait to get to discord and tell the boys I got the clap
Offline soloplayer
« Reply #4 on: Sat, 29 August 2020, 23:21:38 »
filled the IC form. pls read it and consider yourself  ;D
Offline NathanCVII
  • Weeb I am
« Reply #5 on: Sat, 29 August 2020, 23:34:43 »
Dam, she thicc
Offline alleneentrekin
    • j
« Reply #6 on: Sat, 29 August 2020, 23:42:41 »
Filled out IC and left a long piece of feedback. Good luck with your first board!
Sent from my Pixel 4 XL using Tapatalk
Offline GaNeBaL
« Reply #7 on: Sun, 30 August 2020, 00:07:01 »
damn, damn boi, DAMN BOI HE THICC BOI, THAT'S A THICC ASS BOI, DAMN
Obsessed with 60%TKLs
Offline halocantkb
  • Formerly 'shota_irl'
« Reply #8 on: Sun, 30 August 2020, 00:27:51 »
a few things to note with the plate (from the renders you've showed)
- spacebar stabilizer should be flipped
- consider alternative layouts (split backspace, iso, stepped caps)
some other misc stuff:
- consider adding a small space for your daughterboard cable to reduce strain
- there seems to be no fillet/chamfer on the blocker, might be pretty sharp. (correct me if I'm wrong)
- as others have said, that front edge is really tall, I'm worried it might not be comfortable to type on
- in the future, I'd reccomend getting more community feedback and revising before ordering prototypes as a new designer
Sent from my ELE-L04 using Tapatalk
Offline deedz
« Reply #9 on: Sun, 30 August 2020, 00:54:37 »
Also voicing the front height looks extremely tall and uncomfortable. I’d say the front height of just the bottom piece seems more comfortable ergonomically.
Also maybe a WKL design? Just personal preference though
« Last Edit: Mon, 31 August 2020, 02:07:19 by deedz »
    • j
« Reply #10 on: Sun, 30 August 2020, 09:12:18 »
As others have said. I think you are going a little bit fast with the prototype, I'd consider waiting for more feedback before you order prototypes.
« Last Edit: Sun, 30 August 2020, 09:14:07 by alleneentrekin »
Offline zoo
    • zoo
« Reply #11 on: Mon, 31 August 2020, 01:34:01 »
The tabs on the weight look very small. Larger tabs would make for a more enjoyable assembly process.
Offline Suavity
  • Smile more! 🙂
« Reply #12 on: Mon, 31 August 2020, 03:24:04 »
Any considerations for a split space bar?
Offline typeaudesign
    • Typeau Design.
« Reply #13 on: Mon, 31 August 2020, 04:28:05 »
Definitely going to need a wrist rest for this one :D Nice colors though!
Offline Jyobah
« Reply #14 on: Mon, 31 August 2020, 09:03:55 »
Does this give you the CLAP?  :p
Offline Kinesiologist
« Reply #15 on: Mon, 31 August 2020, 10:25:50 »
saw this on ZF, looking good :D
Offline raz0r54
« Reply #16 on: Mon, 31 August 2020, 13:59:56 »
very different than the first time I saw this a couple days ago, but this new design I really like :)
Offline 3yatt
« Reply #17 on: Mon, 31 August 2020, 15:38:14 »
Love the redesign. Would love to see this with a brass or ss weight. Definitely interested in the new direction.
Offline lolafineday
« Reply #18 on: Mon, 31 August 2020, 16:01:21 »
I like the location of the logo, but I dont really nice the back design.
Sent from my SM-G975F using Tapatalk
    • j
« Reply #19 on: Mon, 31 August 2020, 17:05:57 »
Love the redesign, but not a huge fan of the back right now, and it really complicated to machine.
Offline sartori24
  • hello
« Reply #20 on: Mon, 31 August 2020, 18:38:51 »
It looks much better! Some renders aren't showing up though.
yikes
« Reply #21 on: Mon, 31 August 2020, 22:09:51 »
Thank you!! Helped me a lot!
    • j
« Reply #22 on: Tue, 01 September 2020, 09:46:59 »
Please consider adding renders with keycaps!
Offline The.Ryan.Gamer
« Reply #23 on: Wed, 02 September 2020, 09:07:34 »
Really interesting. I hope you have option for both hotswap and soldered PCB.
Also you have discord?
Offline Timbersawdust
  • aka snorlax
« Reply #24 on: Wed, 02 September 2020, 11:17:58 »
What is the significance behind the 'No.1' blocker?
« Reply #25 on: Wed, 02 September 2020, 22:54:11 »
Glad you like it!  ;D
« Reply #26 on: Wed, 02 September 2020, 22:56:30 »
Because it is my first keyboard?
Thank you!
Yes it will have hotswap
Will do~
« Reply #27 on: Wed, 02 September 2020, 23:46:13 »
Soooooo! Do you think November GB is possible? Or earlier?  ;D
Offline deedz
« Reply #28 on: Thu, 03 September 2020, 00:15:23 »
Digging the new update, good job!
Hope the front height isn't too tall though. Looks pretty thick
Offline sartori24
  • hello
« Reply #29 on: Thu, 03 September 2020, 05:51:30 »
looks really nice now!
yikes
    • j
« Reply #30 on: Thu, 03 September 2020, 06:29:15 »
I like the revamped back design, but on the inside of the case, the writing "A 65% by Clap Studio" is in a bit of a weird font. Personally I would go for something a little less comic sans esque.
« Reply #31 on: Thu, 03 September 2020, 08:06:51 »
Haha I got that a lot today, going to change to regular A*ial please don't sue me :D
« Reply #32 on: Thu, 03 September 2020, 08:09:18 »
Glad you like it!
Offline Janoma
  • certified nerd
« Reply #33 on: Thu, 03 September 2020, 08:28:47 »
I sorta dig that no 1 blocker :eek:
    • j
« Reply #34 on: Thu, 03 September 2020, 09:25:01 »
Awesome thanks!
Offline idolindisguise
« Reply #35 on: Thu, 03 September 2020, 09:33:16 »
very nice design
Offline stoked71
« Reply #36 on: Thu, 03 September 2020, 10:34:16 »
I like the all the design choices except for the logo and font. Kind of comic sans ish  :-[
