Author Topic: List of mx-compatible linear "speed" switches  (Read 1536 times)
Offline Learis
« on: Thu, 03 September 2020, 01:21:10 »
By "speed" switch, I mean that it has less total travel than the typical 4mm. So I'm looking for all linear switches with less travel distance than 4mm.
So far I know of:
Cherry speed silvers (1.2mm actuation, 3.4mm total)
Gateron ink yellows (?? actuation, 3.4mm total)
Kailh speed silvers (1.1mm actuation, 3.5mm total)
Am I missing any others?
Edit:
Kailh Box (1.8 mm actuation, 3.6mm total)
Kailh Pro (1.7mm actuation, 3.6mm total)
Kailh Regular (2.1mm actuation. 3.8mm total)
« Last Edit: Sun, 27 September 2020, 00:39:49 by Learis »
Mend and Defend
Offline Merranza
Re: List of mx-compatible linear "speed" switches
« Reply #1 on: Thu, 03 September 2020, 14:47:06 »
If your definition of speed is less than 4mm total travel, we can add Kailh pro burgundy:
Kailh Burgundy – Linear 50g | 1.7mm | 3.6mm (operating force/travel/total travel)
They are pretty nice to type on even stock to be honest.
Offline Learis
« Reply #2 on: Thu, 03 September 2020, 18:24:48 »
Indeed, thank you... I think that's the lot of them, unless there's some random obscure ones out there.
Mend and Defend
