Author Topic: [HELP] Problem with VIA ISO layout (pipe key and #)  (Read 3952 times)
Offline ignBenjamin
« on: Sat, 05 September 2020, 11:13:11 »
https://imgur.com/a/NRQfDeb
I am having problems with my ISO layout on my KBD67MKII using VIA. My pipe key ( | and \ ), in the bottom left next left shift, is activating my hashtag (#) and tilde (~).
In the key tester both the hashtag and pipe key activate like this: https://imgur.com/a/Fsloebz
And in text matrix the pipe key activates in the correct place and the hashtag doesn't appear to activate at all. see here: https://imgur.com/a/rf4S51F
Re: [HELP] Problem with VIA ISO layout (pipe key and #)
« Reply #1 on: Sat, 05 September 2020, 11:49:16 »
Sounds like you're using a US keycode instead of an ISO one and/or the tester is reading the character the operating system says rather than adjusting for layout, like this one does.  What does Aqua Key Test think you're pressing?
Offline ignBenjamin
« Reply #2 on: Sat, 05 September 2020, 12:04:55 »
Yep, this was the problem. Just figured it out on my own.
Thanks for your reply anyways!
Offline Fertan
« Reply #3 on: Sat, 12 September 2020, 07:44:02 »
Hello,
I have the same kind of issue from several days. When i press my caps lock (configured in via) it is recognized as left ctrl, when i press windows key it is recognized as left alt, and when i press my alt key nothing happens. Can you help me to fix it ? I'm a bit lost :(
My keyboard is a kbd67mkii hotswap, and before the last week it was perfectly working ...
Thanks for the help guys.
