Author Topic: The Womier K87 has good modding potential!  (Read 4299 times)
Offline Hipyo
    • Youtube
« on: Sun, 06 September 2020, 13:07:38 »
Howdy! I did what y'all were recommending and brush lubed a keyboard! The womier k87 is very very cheap and I wanted to see how good I could get it sounding.
Let me know what you think of the mod and I would really appreciate some feedback as I havent really done this before with tactile switches.
Offline Drakenocas
Re: The Womier K87 has good modding potential!
« Reply #1 on: Tue, 15 September 2020, 13:40:31 »
Not bad. Not bad at all.  I think if you want that space bar right, you may have to put some actually non-factory stabs in there. I thought that was hair a little to much grease on them for my preference.  Have you bandaged modded it? Double checked that the wire, as well as the space bar, straight?  You could also try a linear switch in the space bar first.
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Fri, 18 September 2020, 15:56:12 »
good job it works well
lots of rgb
Puddsy typing moment
Everyone must pay the cat tax
