Author Topic: Rigid plastic  (Read 8849 times)
Offline iandoug
Rigid plastic
« on: Mon, 07 September 2020, 11:55:26 »
hi all
I need to make another keyboard... another sandwich style.
The first one had an aluminium plate with perspex for the other layers. I had to have them laser cut in two places... and their kerfs were different and so things didn't quite line up. And the switch holes ware fractionally too small, I had to file them bigger with mixed results.
So I was thinking if it would be viable to also have a plastic plate ... but which material is rigid enough? Is their a suitable laser-friendly perspex/polycarbonate/whatever?
I actually bought a brass plate years ago, but would need to sort out the kerfing issues. I did ask the vendor about their kerf settings but he strangely didn't understand what I was on about ....
Thanks, Ian
Offline nevin
Re: Rigid plastic
« Reply #1 on: Mon, 07 September 2020, 14:04:50 »
polycarb plates (usually half plates) are popular. polycarb is softer and much more pliable than acrylic. some have machined cases from large blocks of polycarbonate.
acrylic (perspex) is probably the most popular stacked/layered style case.
- check out qlavier for inspiration, they do beautiful layered cases
FR4 make good plates and most are semi transparent (will diffuse light) depending on the finishing of the top & bottom surfaces
- you can do a really cheap spaced FR4 case. FR4 plate, pcb, FR4 bottom plate all held together with standoffs
another option would be to 3d print. or even better, 3d resin print
as far as vendors... check
http://builder.swillkb.com/    https://lasergist.com/ (stainless steel)
https://www.ponoko.com/ (all kinds of materials)
see what other vendors are suggested, these are the couple that i know of, may depend on your location as well.
« Last Edit: Mon, 07 September 2020, 14:07:47 by nevin »
Offline dusan
Re: Rigid plastic
« Reply #2 on: Sat, 12 September 2020, 16:39:00 »
You already know the true kerf, right?
For shaft, actual kerf = sketch size - actual size
For hole, actual kerf = actual size - sketch size
So why not use your preferred material - aluminum and perspex?
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
