Author Topic: Hello! Switch and keycap compatibility  (Read 2528 times)
Offline Mel
« on: Wed, 09 September 2020, 14:47:25 »
Hello, after being interested in mechanical keyboards for awhile, I've decided to finally build my first keyboard. I'm fairly certain I want to use NovelKeys Creams for my switches, and was wondering if they are compatible with GMK style keycaps? Never hurts to check.
Offline soondubu
Re: Hello! Switch and keycap compatibility
« Reply #1 on: Wed, 09 September 2020, 15:11:02 »
Yup, they are! All switches with the"cross-shaped" stem are compatible with GMK, SA, KAT, MT3, and most other keycaps that are on the market unless they are specified as otherwise.
Sent from my SM-G973U using Tapatalk
Offline Mel
« Reply #2 on: Wed, 09 September 2020, 15:27:53 »
