Author Topic: [IC] Noxary Valhalla - Gasket Mounted Ergo 65% (Prototype Arrived)  (Read 28757 times)
Wonderfool and 1 Guest are viewing this topic.
Offline xondat
  • i'm not a star
« on: Sun, 13 September 2020, 19:18:51 »
Reposting from the Discord where all the conversation happens :thumb:
TLDR - Everything looks great apart from a couple minor things noted below.
Going to move the position of the two visible screws by 2/3 and 0/-, these will be moved outwards one key from the middle to 1/2 and -/= so they aren't as visible. Build isn't final as I haven't received the gasket strips yet, so will have more angles of the proto when they arrive. These have just finished production and look great, image below.
Valhalla
An ergo 65%, developed from the ground up. Featuring Noxary DUAL V2 Mount, no visible screws, and a seamless case design, Valhalla is the first in Series 3 - the next generation of Noxary boards.
Mounting
The Noxary DUAL V2 Mount uses custom o-ring shaped strips. They sit both above and below the plate, around the perimeter, to perfectly emulate two large diameter o-rings. The unique shape of the strips enable precise control over plate movement, creating a unique sound & feel.
Layout
Compared to existing ergo options, the distance between the two halves is increased ~150%, whilst the alpha tilt is decreased from 12 degrees to 8. Along with the Noxary LEDGE, which lowers the front height, the typing comfort is improved greatly.
The bottom row features 1.5 - 1 - 1.5 caps on each side, with a 2.75u spacebar on the left, and 2.25u on the right. The 2.75u can be split into 1.75 - 1u, and the 2.25u into 1 - 1.25u. The traditional options of full or split Backspace, and regular or stepped Caps Lock remain.
Design
The design is unmistakably Noxary - a low front & clean side profile. The DUAL Mount is designed not only to produce a unique typing experience, but also to hide any screws on the outside. The front corners made by tilting the alphas have been curved too. These four elements combined creates the signature aesthetic.
Connection
The PCB is designed by Gondolindrim, and has been kept simple. Switches must be soldered as this provides the best overall typing experience, and there are no in-switch LEDs. The physical layout options have been kept to a minimum, and can be fully programmed through VIA firmware. A USB-C daughterboard is centrally located between the two alpha halves.
Anodizing Colors & Plates
Anodizing Colors:
  • Blue Gray
  • Lightning Silver
  • Irish Green
Plates:
  • Aluminum (Anodized Lightning Silver)
  • Brass (Sandblasted & Clear Coated)
  • Polycarbonate (Frosted White)
Details
Specification:
  • Ergo 65% with 8° Alpha Tilt
  • DUAL V2 Mount
  • Screwless Exterior
  • Seamless Case Design
  • 7° Base Angle
  • 15.5mm Front Height ft. LEDGE
  • USB C Daughterboard
Contents:
  • 1 x Top ( Aluminum)
  • 1 x Base (Aluminum)
  • 1 x Plate (Aluminum [1.5mm] or Brass [1.5mm] or Polycarbonate [Thickness TBC])
  • 1 x Main PCB
  • 1 x Daughterboard PCB
  • 1 x PCB Cable
  • 10 x DUAL V2 Strips
  • 7 x M2 Hex Screws
  • 4 x Custom Rubber Feet
Preorder Information:
The prototype is currently on order, and is expected to be received early-mid October. The units will be sold via preorder on noxary.co via FCFS. The date and time will be announced once the prototype is built. The price will be confirmed within the next 2 weeks, however it is expected to be ~$500. There will be 75 units available for preorder, with no extras being available afterwards. Lead time will be 6 months from preorder closure to delivery.
Further Links:
« Last Edit: Tue, 27 October 2020, 01:22:16 by xondat »
Offline OtherAndrew
Re: [IC] Noxary Valhalla - Gasket Mounted Ergo 65%
« Reply #1 on: Sun, 13 September 2020, 19:19:50 »
yes
Offline Gondolindrim
    • My GitHub
« Reply #2 on: Sun, 13 September 2020, 19:19:56 »
HYPE
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline phat schlong
« Reply #3 on: Sun, 13 September 2020, 19:19:58 »
nutty
Offline lac29
« Reply #4 on: Sun, 13 September 2020, 19:20:14 »
Nice, looking forward to this.
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #5 on: Sun, 13 September 2020, 19:20:25 »
YUMMY
(credits to Kokaloo)
Offline 002_GT
  • KR Boards OP
« Reply #6 on: Sun, 13 September 2020, 19:21:04 »
Very nicely done xondat
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #7 on: Sun, 13 September 2020, 19:21:12 »
Nice
Sent from my SM-G970F using Tapatalk
Offline Micoo
« Reply #8 on: Sun, 13 September 2020, 19:22:16 »
Irish Green with Beige  :eek:
Offline Tonkatonk
« Reply #9 on: Sun, 13 September 2020, 19:22:19 »
Noxary daisuki, I can't wait to add this board to my collection :3
Noxary PC268.2 | Red Nunu | Purple PC Nunu | Ogre | Vulcan Pro
Offline perryhuynh
« Reply #10 on: Sun, 13 September 2020, 19:23:31 »
nut
Hiney TKL One | JinSoul | KFE | Matrix 8X V2.0 | Nunu (Aluminum) | Nunu (Polycarbonate) | Ogre | Seulgi | Vulcan Pro | Yeji | Yeri
Offline noricon
« Reply #11 on: Sun, 13 September 2020, 19:26:52 »
yes.
Offline Zeelobby
« Reply #12 on: Sun, 13 September 2020, 19:27:21 »
Here we go
Offline SnowyMinion
« Reply #13 on: Sun, 13 September 2020, 19:27:51 »
That green so good...
Offline Midori
  • Formerly loktrevor
  • c:
« Reply #14 on: Sun, 13 September 2020, 19:28:29 »
very cool, very nice, i am fan
TGR Jane v2 | Vulcan Pro | Matrix 8X v2.0 | Bean | hbcp | froge | hype hen
Offline alwayswarren
« Reply #15 on: Sun, 13 September 2020, 19:28:41 »
count me in
Offline of_sam
« Reply #16 on: Sun, 13 September 2020, 19:29:20 »
Looks solid. GLWB.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline SirShakes
« Reply #17 on: Sun, 13 September 2020, 19:29:38 »
gimme that green
Offline whitemamba
« Reply #18 on: Sun, 13 September 2020, 19:30:02 »
Gimme plz  ;D
Offline Lulzthax_
« Reply #19 on: Sun, 13 September 2020, 19:31:08 »
valhalla has been considered and conclusion is yes.
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #20 on: Sun, 13 September 2020, 19:35:08 »
nice
Offline Tree_
Offline skrunk
« Reply #22 on: Sun, 13 September 2020, 20:13:12 »
very nice board! excited for this one!
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline soloplayer
« Reply #23 on: Sun, 13 September 2020, 21:23:45 »
if only there were a brass weight  :(
but this is good enough. count me in  ;D
Offline megaforce
« Reply #24 on: Sun, 13 September 2020, 21:48:45 »
I wanna enter xondats personal Valhalla
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline o3okevin
« Reply #25 on: Sun, 13 September 2020, 22:40:23 »
Nice board dude
Offline samanth
  • Thocc
« Reply #26 on: Sun, 13 September 2020, 22:51:09 »
I'm fascinated by the design. It's so clean and smooth. That's an awesome looking board. :thumb:
Offline zoo
    • zoo
« Reply #27 on: Mon, 14 September 2020, 10:18:41 »
This is so good
Saw the product page linked in discord first, and the featured details are so thoughtfully done
Offline Ramen Champ
« Reply #28 on: Mon, 14 September 2020, 11:01:12 »
I generally think "ergo" alice boards with arrow keys often looks off balanced - but this one seems well done with the implementation of the close nav cluster on the right. Quite beautiful, as always, Xondat!
twitch.tv/ramenchamp_
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #29 on: Mon, 14 September 2020, 11:22:00 »
Looking super clean!
Offline super_tu
« Reply #30 on: Mon, 14 September 2020, 11:24:14 »
I'm here for this+
Offline Dafraz117
« Reply #31 on: Mon, 14 September 2020, 11:29:07 »
Gibme
Offline dantambok
« Reply #32 on: Mon, 14 September 2020, 12:02:19 »
give
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline leandrovega
« Reply #33 on: Mon, 14 September 2020, 14:11:32 »
Great design. Clean. Neat. Looking forward to this one.
Offline juaninamilli
« Reply #34 on: Mon, 14 September 2020, 14:11:50 »
This looks fantastic!
Offline xondat
  • i'm not a star
« Reply #35 on: Mon, 14 September 2020, 15:20:27 »
I agree, none of them satisfied me so I did it myself. No regrets spending months on the layout :p
Offline stoffelduss
« Reply #36 on: Mon, 14 September 2020, 15:33:08 »
wow, this looks sick!
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #37 on: Mon, 14 September 2020, 18:33:31 »
0_0
Offline holer
« Reply #38 on: Tue, 15 September 2020, 04:39:00 »
Looks fantastic!!
Does the PCB (and plate) support split L-Shift (2.25 to 1.25 + 1)? If it doesn't then please consider adding it <3
Offline MyManMart
« Reply #39 on: Tue, 15 September 2020, 05:57:54 »
The green is so good. Very well put together board.
Offline xondat
  • i'm not a star
« Reply #40 on: Tue, 15 September 2020, 11:26:10 »
Looks fantastic!!
Absolutely!
Personally I'll be keeping the spacebars full width, but I know there is a good portion of people that want the extra key or two there :)
Offline Zurg Eon
« Reply #41 on: Tue, 15 September 2020, 15:02:43 »
I'd be in for that Irish green  :)
Offline holer
« Reply #42 on: Tue, 15 September 2020, 16:43:02 »
Looks fantastic!!
Absolutely!
Offline johnnysstash
« Reply #43 on: Tue, 15 September 2020, 21:31:45 »
HOLY hell yes, see you in valhalla bois!
Offline noorejji
« Reply #44 on: Wed, 16 September 2020, 03:07:49 »
You forgot to add that render you made with Nautilus Nightmares.
Offline xondat
  • i'm not a star
« Reply #45 on: Wed, 16 September 2020, 11:14:42 »
The only person that's completed renders with this keyboard is Janglad, and they're all present here :confused:
Offline FilthyMike720
« Reply #46 on: Wed, 16 September 2020, 18:14:47 »
This looks incredible xondat, great work. I'm definitely going to try for silver.
Offline baksbaks
  • don't be so angry all the time
« Reply #47 on: Wed, 16 September 2020, 22:44:34 »
smells delicious. see you with the vikings.
Offline lemmebuildthings
  • Why did I get into this god forsaken hobby
« Reply #48 on: Mon, 21 September 2020, 16:28:24 »
This is looks super clean. Definitely something I wanna cop!
Offline xondat
  • i'm not a star
« Reply #49 on: Fri, 25 September 2020, 06:30:40 »
After receiving manufacturing feedback, and giving it a lot of thought, the mounting system in Valhalla will be upgraded to DUAL V2. This will feature several semi-circle strips in replacement of the o-rings. The new semi-circle strips are designed to exactly replicate the compression that'd occur with an o-ring, therefore providing the same typing experience. With o-rings, assembly was quite the annoying experience, so the change is a welcomed nice side effect.
I've updated the OP with this info and am happy to answer any questions :)
