Author Topic: Usb motorized keyboard  (Read 5441 times)
Offline Input Nirvana
« on: Thu, 22 July 2010, 00:04:16 »
Obviously, you will never type the same again.
(Check out the nasty hair plugs in the video. Ick!)
http://www.smartfishtechnologies.com/products-keyboard.php
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #1 on: Thu, 22 July 2010, 00:29:49 »
They don't tell you the dimensions of the board.  Even with the combined arrows/num pad/home etc., it looks too long for me.  Is it scissor switches? Seems like that board wouldn't have the same kind of durability as the standard mechanical,given the motion motor, etc.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline mcdonc
« Reply #2 on: Thu, 22 July 2010, 00:48:05 »
That's a yarmakule.
Owned: bunches of Model Ms,  Model F AT, Dell AT101W, Amiga 500.
« Reply #3 on: Thu, 22 July 2010, 00:52:43 »
Quote from: mcdonc;205163
That's a yarmakule.
I almost believed you, till I looked at the video again. He should have waited for the plugs to grow out or worn a wiggie.
Offline Forsaken
« Reply #4 on: Thu, 22 July 2010, 00:56:18 »
It's pretty, I'll give it that much. But I think I'll stick to my Kinesis.
« Reply #5 on: Thu, 22 July 2010, 01:08:17 »
I was thinking I need to stick a motor in my Kinesis to be cool.
Offline chimera15
« Reply #6 on: Thu, 22 July 2010, 01:18:43 »
Pretty interesting...  It's kinda gimmicky.  I have trouble believing that the board separating a few inches will make it more ergonomic, but anything's possible I suppose.
At least it's relatively inexpensive.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Cranergy
« Reply #7 on: Thu, 22 July 2010, 01:21:03 »
I wonder how many people actually believe this kind of stuff... lol
« Reply #8 on: Thu, 22 July 2010, 01:21:09 »
Quote from: chimera15;205173
My point exactly.
That and bad hair plugs.
Offline washuai
« Reply #9 on: Thu, 22 July 2010, 01:22:12 »
I just want to sit someone down at a moving keyboard, without them knowing it moves.  I think it'd make a great practical joke.  Still, reactions to blank and rearranged keys are good enough.
 ✐Intuos or Cintiq
Offline hyperlinked
« Reply #10 on: Thu, 22 July 2010, 02:34:48 »
Quote from: Cranergy;205175
I'll admit to it... I do.
Well, actually I'm not sold that it works, but it's an interesting idea. By its very definition RSI is caused by doing the exact same motion over and over again until your muscles, tendons, ligaments, or joints develop pain or weakness. By changing the typing surface, they in effect change the exact motion that you're repeating, but the question is if it's changing it in any meaningful way.
I don't know if spreading the keys out or tilting the typing surface periodically does enough to change the motion, but it's an interesting idea and assuming the keyboard isn't total crap it'll probably be good for some RSI sufferers. The question is if it'll be more than a niche "therapy" and be useful to a wider audience.
If subtle adjustments like this are enough to reduce stress to your hands, then you might be able to get some of the same effect merely by changing your posture. It's interesting food for thought.
« Last Edit: Thu, 22 July 2010, 02:41:56 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline MsKeyboard
« Reply #11 on: Thu, 22 July 2010, 10:21:47 »
Typed on one at CES January, interesting idea that probably would make a decent product if it had been worked into a good board.
It always seems that the people who come up with these ideas forget that the type (no pun intended) of user this product is aimed towards actually need a better keyboard than the standard "throw one in the box with the new computer" variety.
This kind of system seems like a gimmick, but the need to remind people to step away from the keyboard once in awhile and stretch out your hands and wrists is real.  If this is what it takes for someone, than mission accomplished.
YMMV.........................
Offline firestorm
« Reply #12 on: Thu, 22 July 2010, 10:37:15 »
I could never use that keyboard for the simple fact that I highly dislike flat keys.  There is at least some separation to help you find the keys, but my initial impression is that it is form over function for at least the primary purpose of typing.
Offline gr1m
« Reply #13 on: Thu, 22 July 2010, 10:47:11 »
Quote from: washuai;205177
Or take a screenshot of a desktop with icons and taskbars and all and then set it as the wallpaper and hide the taskbar and icons and whatnot.
« Reply #14 on: Thu, 22 July 2010, 10:51:11 »
Notice the curious arrangement with the numeric and inverted-T cursor keys! The Up key is between 0 and Enter. The large key to the left of them is not comma -- it is delete!
I am talking about the black keyboard in the picture, not the "silver" one in the video.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #15 on: Thu, 22 July 2010, 11:09:59 »
Who needs a motorized keyboard?
Offline ch_123
« Reply #16 on: Thu, 22 July 2010, 11:14:49 »
« Reply #17 on: Thu, 22 July 2010, 11:15:47 »
That's a typewriter. Not a motorized computer keyboard.
Offline ch_123
« Reply #18 on: Thu, 22 July 2010, 11:25:59 »
Depends on how it's hooked up
That woman looks like she is bored out of her skull.
« Last Edit: Thu, 22 July 2010, 11:29:35 by ch_123 »
« Reply #19 on: Thu, 22 July 2010, 11:54:06 »
I feel about the same way she does right now.
Offline ch_123
« Reply #20 on: Thu, 22 July 2010, 11:59:22 »
That's a sign that you need to get off the computer.
Offline Tiberian
« Reply #21 on: Thu, 22 July 2010, 13:47:50 »
Kind of a ridiculous idea in my opinion.
« Reply #22 on: Thu, 22 July 2010, 15:39:16 »
Quote from: ch_123;205277
I prefer to think that she has been up programming for 48 hours straight.
Offline didjamatic
« Reply #23 on: Thu, 22 July 2010, 15:57:51 »
I really like the concept.  I swap keyboards and mice regularly to combat RSI, so something like this could be a real benefit.
Offline Rajagra
« Reply #24 on: Thu, 22 July 2010, 16:48:43 »
Quote from: input nirvana;205155
It does look good IMO. Took me a while to work out what it reminded me of - the Neo Geo console and joystick.
I think the idea is interesting but can't help thinking there has to be a simpler way to achieve the same result. The mouse they do is of more appeal to me.
« Reply #25 on: Thu, 22 July 2010, 17:03:02 »
Quote from: ch_123;205281
I was actually at work where I had to be using the computer.
Offline hoggy
  • * Ergonomics Moderator
« Reply #26 on: Fri, 23 July 2010, 01:07:02 »
Quote from: didjamatic;205424
I do this as well.  I suspect that swapping boards - especially if they are quite different would work a bit better than the motorised keyboard.  However, it was this keyboard that gave me the idea to do that.
There seems to be a vagueness about how often it moves, and by how much - or a least there was when I emailed smartfish a while ago.
