Author Topic: Buying NK Creams  (Read 2167 times)
Offline CarnageHimura
Buying NK Creams
« on: Fri, 18 September 2020, 15:48:50 »
I have the doubt if it's the same to buy the NK Creams on the NK site when they have stock or GB and buy the creams on the Kailh Oficial AliExpress Store.
There are the same Switches?, or are they different?
Offline treeleaf64
    • treeleaf64
Re: Buying NK Creams
« Reply #1 on: Fri, 18 September 2020, 15:50:57 »
Same switches
NK gets from Kailh and Kailh sells on their website , just buy whatever's cheaper . NK should come faster 'cause it's based CONUS
Everyone must pay the cat tax
« Reply #2 on: Mon, 21 September 2020, 12:03:48 »
Thank you!! I'm still deciding between creams or some Durocks, but I had that doubt!
Offline diazel
« Reply #3 on: Mon, 21 September 2020, 12:59:25 »
Solid choices. You won't go wrong either way.
Offline SKx1
« Reply #4 on: Tue, 22 September 2020, 00:50:02 »
Just bought some a few weeks ago. When lubed properly, they feel amazing.  :thumb:
« Reply #5 on: Tue, 22 September 2020, 08:46:45 »
Thanks!! And yes, I'm still amazed by the day/night change on my Kailh Silver's after lubing and flming!!
