Author Topic: What VIM colorscheme do you use?  (Read 10444 times)
Offline glo
« on: Thu, 22 July 2010, 08:44:15 »
For the ones who code in VIM, what colorschemes do you prefer?
I mainly use two:
oceanblack for a dark background
taqua for a light background
Offline vyshane
« Reply #1 on: Thu, 22 July 2010, 10:03:50 »
I use my own colorschemes. Dark background for the terminal:
If I'm using MacVim/GVim and I feel like using a light background, I use vylight (also my own). I posted about it here.
Offline pikapika
« Reply #2 on: Mon, 26 July 2010, 08:41:57 »
i use inkpot
or zenburn
though i'm trying to learn emacs :-)
Offline cmr
« Reply #3 on: Tue, 27 July 2010, 11:07:38 »
koehler, i think?
Offline instantkamera
« Reply #4 on: Tue, 27 July 2010, 14:57:03 »
the default (dark) one. reason is I spend so much time daisy chained onto several different (hundreds) of servers that it is really pointless to pick a theme for my local machine only to have to deal with another one elsewhere.
It would be an awesome idea to roll that Inkpot scheme into our deployment though ...
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline Moparx
« Reply #5 on: Tue, 27 July 2010, 16:06:09 »
IBM Model M | IBM Model F
Offline EverythingIBM
« Reply #6 on: Wed, 28 July 2010, 01:16:17 »
Mine is just plain & bland:
Offline vyshane
« Reply #7 on: Wed, 28 July 2010, 02:21:30 »
Quote from: everythingibm;206996
my troll attempt is just plain & bland:
Fixed that for ya ;)
« Reply #8 on: Wed, 28 July 2010, 08:14:11 »
Quote from: EverythingIBM;206996
Mine is just the worst thing I have ever seen. It is overly cluttered with annoying GUI elements, the interface is getting in the way of the text. However, it clearly demonstrates my worthlessness here. I just like to prove beyond a shadow of a doubt that I really am a tool, and know **** all about anything of any importance whatsoever.
fixé.
Offline vyshane
« Reply #9 on: Wed, 28 July 2010, 22:10:26 »
Quote from: kishy;207097
I agree with that statement until the stupid bar on the right side is closed.
After that, it's a great GUI. Just don't try to use the WYSIWYG part or nothing will work properly in any browser except IE6...
I find TUI editing to be quite frustrating so vi, derivatives and similar make me crazy. Notepad++ for me.
Text editing is pretty simple at its core. You need to be able to:
Open or create a file
Move the cursor to different parts of the document
Type something in
Save a file
You access the new, open, save actions from a menu (or shortcut key). The keyboard and mouse allow you to move the cursor around, and the keyboard takes care of entering text in. Therefore most text editors only need simple GUIs.
A quick look at Textmate or MacVim won't tell you much about either. You may not even be able to tell them apart just by glancing at each for a few seconds.
Both are considered best of breed editors, yet look deceptively simple. Textmate IS simple to get into. Vim has a higher learning curve because of its modal nature.
Offline Xuan
« Reply #10 on: Tue, 03 August 2010, 17:27:59 »
zenburn :)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #11 on: Tue, 03 August 2010, 17:33:44 »
Windows Standard
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #12 on: Tue, 03 August 2010, 17:35:21 »
Pretty sure I used inkpot and zenburn at one point. For the longest while I used a custom terminal colour scheme (which worked great with vim).
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
« Reply #13 on: Tue, 03 August 2010, 18:02:39 »
Quote from: vyshane;205255
Hmm. You're a Mac user. Guess you got plenty of color schemes to choose from.
« Last Edit: Tue, 03 August 2010, 18:05:09 by microsoft windows »
Offline D-EJ915
« Reply #14 on: Tue, 03 August 2010, 18:13:09 »
heh people use IE on newer macs?  I only use it on my old ones because it works better with some pages than Netscape does.
« Reply #15 on: Tue, 03 August 2010, 18:21:42 »
That wasn't a newer Mac.
Offline D-EJ915
« Reply #16 on: Tue, 03 August 2010, 18:32:19 »
That's using OS X and yes that is a newer mac, put camino on it, it's what I use on my snowy imac.
« Reply #17 on: Tue, 03 August 2010, 19:21:15 »
I remember when those iMac's were new, but I never thought you all on Geekhack would consider them to be new.
Offline Brodie337
« Reply #18 on: Tue, 03 August 2010, 20:52:01 »
Back on topic, I have to use the stock colour scheme.
One of the downsides to using an assload of machines. I did try some of the others, and they did look sexier and make life easier, but I gave up trying to keep all of the machines the same.
Offline vyshane
« Reply #19 on: Tue, 03 August 2010, 22:09:21 »
Quote from: Brodie337;208880
What I do when faced with this situation is to theme the terminal colours on my client computers. I can't stand the default colour scheme. I like muted themes that use few colours. Too many colours and I lose the benefit of syntax highlighting. If everything looks different, then nothing is highlighted.
Offline JulienC
  • Esc Artist
« Reply #20 on: Tue, 03 August 2010, 22:40:35 »
One more zenburn user here.
Edit: I'm using the Inconsolata font, which I don't really like. Any suggestions for good programming fonts ? Which one is it in Moparx's screenshot ?
« Last Edit: Mon, 17 August 2015, 21:24:38 by JulienC »
HHKB
Offline pikapika
« Reply #21 on: Wed, 04 August 2010, 09:11:20 »
terminus is a nice font for the terminal
« Reply #22 on: Wed, 04 August 2010, 17:51:36 »
exactly.
« Reply #23 on: Wed, 04 August 2010, 18:06:24 »
Quote from: vyshane;208900
It all depends on:
a) how long/ how much work you have to do
b) language
c) type of application/style of writing (a lot of different/complex data structures, classes etc)
Either way, it CAN get nasty and IF I did a large amount of work instead of just banging out quick scripts, I would care more.
In order from least to most NASTY (using VIM in default colour scheme), the three languages (scripting, primarily) I have to deal with are:
3) Python
2) bash
1) perl
The complete inverse will give you my preference of which to work in (and you can basically drop perl from the list entirely ;))
Offline vyshane
« Reply #24 on: Wed, 04 August 2010, 19:39:31 »
Quote from: instantkamera;209246
It all depends on:
b) language
Agreed. I'm a programmer, so I care about a). I also work on less than 10 different boxes on a regular basis. Keeping my dotfiles in sync is still doable. Having them in a source code repo helps too.
Offline HaaTa
  • Kiibohds!
« Reply #25 on: Thu, 05 August 2010, 00:28:15 »
Quote from: pikapika;209041
It's what I've been using for the past 2-3 years.
Kiibohd
Offline steeef
« Reply #26 on: Tue, 19 October 2010, 15:15:44 »
Sorry to resurrect this thread. I use a modified version of Molokai:
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline WhiteRice
« Reply #27 on: Tue, 19 October 2010, 15:23:01 »
Whatever color my terminal window is set to.
White on blue, or white of black....
Offline Alligator
« Reply #28 on: Tue, 19 October 2010, 19:54:56 »
I use my own colourscheme.
It's called jelly, I'm not sure why.
