Author Topic: [IC] ISO Macro - a macro pad with iso enter key and encoders  (Read 4984 times)
Offline online
« on: Mon, 21 September 2020, 13:58:42 »
252583-0
Hello, I designed a macro pad with 2 encoders which utilized ISO enter keys. Here is an interest check for the upcoming small gb run.
Please fill the IC form
6-degree typing angle
252168-1
3D printed knobs with colours of your choice.
252170-2
Compatible with 15mm knobs on the market
252172-3
Colour options
Galaxy Black
Marble effects
Galaxy Purple
Will continue to update, please fill the IC form to suggest a colour
Specs
QMK firmware
NKRO
125 x 61 x 19mm
USB-C
Intergraded plate
PLA 3D Printed Case
FAQ
When will the GB starts?
Around mid/end of October.
How many will be available to order?
50 for the first run.
What’s the lead time?
Around 3 months.
« Last Edit: Mon, 28 September 2020, 07:22:56 by online »
Offline VagueOrigin
Re: [IC] ISO Marco - a macro pad with iso enter key and encoders
« Reply #1 on: Mon, 21 September 2020, 14:15:05 »
Can think of some uses, im in! I like the layout!
Sent from my SM-G975U using Tapatalk
Offline perry4761
« Reply #2 on: Mon, 21 September 2020, 15:51:35 »
I like it! Is there any chance for a metal case run if there is enough interest? How thick will the plate be? Do you have any pictures of the bottom, of the pcb, and of the case before assembly?
Offline online
« Reply #3 on: Mon, 21 September 2020, 16:35:10 »
Most likely not, but if I can find a reliable manufacturer, then maybe.
The plate is 3mm thick. PCB is sent to prototype, should be with me in around 10 days. I'd prefer not to show the case before assemble yet, but I will do that after PCB arrived and confirmed the fitment.
252178-0
252180-1
Offline marcofriedrichs
  • Discord: Marco#8888
    • marcofriedrichs.com
« Reply #4 on: Mon, 21 September 2020, 23:22:56 »
I like the name
