Author Topic: What the hell type of connector is this?  (Read 4622 times)
Offline Shawn Stanford
« on: Thu, 22 July 2010, 13:37:10 »
I'm not familiar enough to be able to tell if it's an XT or AT...
The Brat Prince of COBOL
Offline ch_123
« Reply #1 on: Thu, 22 July 2010, 13:38:31 »
The connectors are identical.
Keep looking, my son.
Offline EverythingIBM
« Reply #2 on: Thu, 22 July 2010, 13:59:32 »
Quote from: ch_123;205317
Which also happens to be identical to MIDI ports.
I wonder what would happen if I hooked up the XT keyboard to a MIDI connector... hm....
Offline ch_123
« Reply #3 on: Thu, 22 July 2010, 14:06:04 »
Are you sure?
« Last Edit: Thu, 22 July 2010, 14:09:23 by ch_123 »
« Reply #4 on: Thu, 22 July 2010, 14:09:23 »
Quote from: ch_123;205334
No they're not.
Look harder...
Yes they are! I even connected the keyboard to a MIDI connector. They're probably not compatible, but they are the EXACT same connector.
« Reply #5 on: Thu, 22 July 2010, 14:10:35 »
Are you sure?
It was a little stiffer to get in the MIDI connector (due to the little metal latch thingy to hold it in place), but all pins fit in nicely.
Offline didjamatic
« Reply #6 on: Thu, 22 July 2010, 14:11:20 »
CH, what is your Avatar?  Hard drive enclosure?  Air freshener?  Prophylactic dispenser?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #7 on: Thu, 22 July 2010, 14:11:58 »
All that plug is is a standard DIN plug. I see them all over the place from keyboards to loudspeakers.
Offline ch_123
« Reply #8 on: Thu, 22 July 2010, 14:14:45 »
Quote from: EverythingIBM;205336
I have a keyboard (Piano variety) set up near my PC, so I see the Midi connector a lot. I kept on thinking that it had a shorter spacing between pins, but looking at a picture, I can see that they are the same. My bad.
All of the above - it's one of these.
« Last Edit: Thu, 22 July 2010, 14:17:57 by ch_123 »
« Reply #9 on: Thu, 22 July 2010, 14:15:23 »
Quote from: microsoft windows;205340
Which makes you wonder what kind of crazy stuff you could do...
Although, wouldn't want to short any of my MIDI equipment (or my intellistation) for that matter... with a stupid XT keyboard.
« Reply #10 on: Thu, 22 July 2010, 14:18:29 »
Quote from: ch_123;205343
I have a keyboard (Piano variety) set up near my PC. I kept on thinking that it had a shorter spacing between pins, but looking at a picture, I can see that they are the same.
You're always taking the devil's advocate when I state something.
hmmmm....
« Reply #11 on: Thu, 22 July 2010, 14:20:24 »
Quote from: kishy;205347
Just to confirm again, AT and XT use the exact same DIN shell. However, I believe the actual form of the plastic part differed between the AT and XT Model Fs. I don't know for sure but I believe XT is a metal housing and AT is the black plastic...but again, I don't know for sure.
The XT connector head is plastic except for the pins & cylindrical metal shell.
« Reply #12 on: Thu, 22 July 2010, 14:22:36 »
I thought he was just joking. Surely everyone knows that lavender box which was copied from IBM's netvista:
(okay I'm joking. I still think the IBM one looks better)
Offline didjamatic
« Reply #13 on: Thu, 22 July 2010, 14:26:40 »
That O2 is pretty unique.  Google images says some of them came with (or were used with) the dampened alps SGI 101's.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #14 on: Thu, 22 July 2010, 14:30:39 »
Just checked my XT (dunno) and AT (1988) cables, identical connectors. Logo artifacts are nearly the same.
However, the cable itself is different. The AT cable is a bit thicker.
I'm not going to cut them to compare, but I'd say the AT cable is about 1mm thicker. It's easier to compare the coiled portion, as I can see the difference there, rather than having to feel it out.
Oh and the XT cable on my board is quite a bit shorter than the AT one.
XT:
Coiled portion: 1/2 as long
Coiled to Board: 1/2 as long
Coiled to DIN: 1/3 as long
Interesting.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline ch_123
« Reply #15 on: Thu, 22 July 2010, 14:31:58 »
I think by that late stage it was mainly NMB rubber dome keyboards. The AT-101 was more associated with the Indy and Indigo 2. The original Indigo had a dampened Alps keyboard that was PS/2 incompatible despite having the same plug...
« Reply #16 on: Thu, 22 July 2010, 15:22:59 »
Quote from: didjamatic;205339
The Silicon Graphics OČ.
It was pretty fly for '96. I programmed VR cube software on one in college. Everyone at the lab referred to it as "the toaster". The one I used had a SGI granite keyboard with Alps switches assigned to it.
I think that the standard keyboard that came with it was a rubber dome made by NMB, but in the granite colour scheme. 3.5 mm key travel. Very low resistance so that you bottom out easily, but hard. It has a curved steel back plate with all keys the same profile. I used that keyboard on a SGI Octane at work later the same year. The same keyboard but in white was also bundled with the Dec AlphaStations that I also used in college.
The mice that was bundled with the late SGIs was a Logitech Pilotmouse in "granite" plastic. It had three buttons and not a stupid mouse-wheel. I got a SGI mouse / keyboard (NMB) combo for 3 euros at a computing recycling center a few years ago ... just so that would have a replacement when my current Pilotmouse fails ... but it hasn't done so yet.
« Last Edit: Thu, 22 July 2010, 15:35:01 by Findecanor »
« Reply #17 on: Thu, 22 July 2010, 15:52:09 »
And if I remember my GH-lore correctly: XT keyboards are not compatible with modern PCs, but AT keyboards need an inexpensive in-line adapter. Correct?
Offline ch_123
« Reply #18 on: Thu, 22 July 2010, 15:55:39 »
I found two SGI mice in a skip once, both work fine, but I've never really used them...
I'd like to find an O2, but I don't really have the money to make buying one for the lulz feasible. Hoping that my college will dump out some of the ones that they have buried away somewhere.
« Reply #19 on: Thu, 22 July 2010, 17:00:23 »
Maybe you should ask for them.
