Author Topic: Model M Parts Thread - Post your M innards!  (Read 1226 times)
Offline fricked
« on: Mon, 28 September 2020, 20:01:40 »
IBM has tweaked their Model M design over the years, I thought it would be a good idea to make a thread to document this.
I noticed several differences while working on an M to F conversion kit. Check out the interest check (deskthority.net/viewtopic.php?f=7&t=24559) if you are interested - price would be $80 USD but we have yet to hit MOQs  :(
I would love to see what Model M parts you have, please share in the comments and post pics if you can. Lexmarks/Unicomps etc are all welcome!
I will start. I have 3 variants:
IBM 1390120   02DEC86
SDL controller sits on the back
Membrane is glued to the rainbow back plate
The spacebar stabilizer guides are glued to the top so there are no holes like in later models; it also has these on both of the 2u numpad keys
IBM 1395665   12-05-91
Controller with non-removable cable screws into the back plate like this
but the bottom case still has the mounting tabs for the SDL controller!
Stabilizer guides for the spacebar are now built into the barrel plate - this presumably makes them harder to break but it creates holes in the barrel plate (due to the manufacturing process)!
Unicomp 1394204   May 17, 2000
The mounting tabs for the SDL controller are gone
Channels for guiding spills through the board, but it seems a bit pointless when there are still holes for the spacebar
