Author Topic: Kailh Low Profile Switches  (Read 9485 times)
Offline Frisby
« on: Mon, 28 September 2020, 23:55:28 »
I was thinking about building a low profile kailh keyboard. I have heard that it is hard to find compatible parts like the PCB.
So my questions are, can any PCB be used for the kailh low profile switches? If not, what about the switch and PCB make them non-compatible? Finally where could I possible find a PCB for these switches?
Re: Kailh Low Profile Switches
« Reply #1 on: Tue, 29 September 2020, 01:40:08 »
Welcome to Geekhack!
Kailh's most common low-profile switch is called "Kailh Choc".
They are incompatible with Cherry MX because they have the pins at the bottom in a different arrangement. In other words, they will not physically fit PCB made only for Cherry MX-style switches.
There are a bunch of PCBs out there for Kailh Choch, and even some that can actually fit both Kailh Choc or Cherry MX. They tend to be sold by small stores that cater exclusively to the enthusiast market, and in group orders here on Geekhack.
Some of the PCB designs are "open source"/"open hardware", and the schemas can be found on Github and other free repository sites.
However ... most of these PCBs are for layouts that are minimalist, columnar and/or ergonomic though. One contributing reason for this is that the keycaps that Kailh makes for them have unusual non-standard sizes for some inexplicable reason. (both in the size of a 1×1 unit key and the number of units wide some are)
I have heard of a new keycap profile coming, but they have the same restrictions as Kailh's.
Only mainstream ready-made keyboards with Kailh Choc switches come with keys in standard sizes and layouts.
There are dozens of stores out there but most that do sell only a single kit. From the top of my head, I can mention keeb.io. keycapsss.com. splitkb.com.
The Japanese store yushakobo.jp has a lot — minimalist low-profile PCBs seem to be very popular in the keyboard scene over there.
In a couple years time, I think we will have moved away from Kailh Choc though, and towards Cherry MX Low Profile and clones. Neither of these are pin-compatible with Cherry MX either though, despite the name (which Cherry had chosen for marketing more than anything else...)
These fit most keycaps for Cherry MX, if the keyboard does not have a plate above the PCB. Kailh's "Choc V2" has the same shape and size as Cherry MXLP but a different pinout, and TTC is making a clone that is pin-compatible. The clones are not generally available and it's a bit of a chicken-and-the-egg situation for stores if there are so few PCBs available.
What kind of keyboard are you looking at building?
« Last Edit: Tue, 29 September 2020, 01:43:24 by Findecanor »
Offline Frisby
« Reply #2 on: Tue, 29 September 2020, 09:28:29 »
I am looking to build a 65% non-split ortholinear keyboard. If I can't find the parts for one then a 60% or TKL
« Last Edit: Tue, 29 September 2020, 09:32:58 by Frisby »
Offline LASERman Projects
  • Soldering is my native language.
« Reply #3 on: Tue, 29 September 2020, 09:42:57 »
There are retail Low profile TKL keyboards with low-profile switches (Kailh-Choc or equiv.).
They are almost certainly the ONLY source for key caps with all legends to fit those switches.
BTW those low-profile switches give quite different typing experience even comparing to MX style "low-profile" or "speed" ones.
For all above reasons I just got rid of my Keychron K1 low-profile TKL (Gateron low-profile switch - very similar but not compatible caps with Kailh-Choc).
