Author Topic: [IC] The Brick 65 - Final version  (Read 24739 times)
Offline jmSur
« on: Tue, 29 September 2020, 13:40:24 »
The Brick 65
Above image is a PC Brick version. You can put ARGB LED Strips below that PC Brick.
Imagine light coming up from bottom and you put your lego figures on that!
You can check the grooves below the PC brick.
The render on the above image is the initial design of The Brick 65(typing angle with 6 degrees).
Honestly speaking, I like this design much more.
But...if keycaps are put into the keyboard,
the keycaps may hinder the brick. And it will not look so good.
So I raised the brick upper surface 10mm.
But still I am interested on the initial design, and may develop further with a bit higher typing angle.
Various bricks I am gonna make.
I Will provide variety of bricks,
including bricks for artisan keycaps,
bricks for lego figures, tray bricks,
and a brick with function keys and knob(if I can find a PCB supplier to make a PCB which supports all that functions) etc.
If you have a good idea for bricks, please visit my discord server and let me know.
Above pics shows The Brick 65 with a transparent PC brick for artisan keycaps
and a half sized brick.
[Specification]
•  Typing angle: 6.5 degrees
•  Material
    - Upper case: Alu 6063 or 6061 (Not fixed yet)
    - Bottom case: Alu 6063 or 6061 (Not fixed yet)
    - Brick: Alu 6063 or 6061 / Polycarbonate / Wood / and other materials !
•  65 Layout
•  Will support 2 X ARGB connectors (which you can see on the motherboards) on PCB
    - There are grooves below the brick for ARGB LED Strip installation
•  Will provide various bricks !
•  Aluminum plate. Will support stepped caps/split backspace/1.75u and 2.75u right shift, ANSI/ISO, Screw-In-Stabs
•  Burger mounted on upper(top) case
•  PCB - Currently On-going
    - Supports ANSI/ISO
    - Soldered or Hotswap NOT fixed yet
    - Screw-In-Stabs
    - Supports 2X ARGB Connectors for ARGB LED Strips
    - Will be Powered by QMK
    - Will support VIA Configurator
    - USB-C on a daughter board
[Other Information]
Hi everybody!
This keyboard is called 'the Brick 65',
not only because of you can put your lego bricks on the keyboard,
but also you can change that huge brick to another one.
Prototype drawings have been finished, but I will consider and reflect any suggestions from you!
This is why I have opened this IC although another IC/GB by me is on-going.
I will start the Brick 65 GB right after 'Nyaong 75' GB.
•  MOQ : TBD
•  Estimated Price : TBD
•  Ships worldwide
Thank you for reading my thread.
Hope many of you are interested on my keyboard.
Detailed info can be found on below discord server.
•  Discord : https://discord.gg/akrfNJC
----------- Updates -----------
Below is the final version of The Brick 65.
I have modified some rounded corners and name plate angle etc.
There will be no more modification to the outer line.
So, the design is final!
(Currently, poll about 'attaching handles or not' is on-going in my discord server.
If attaching handles' wins, I will put handles to the keyboard. This will be the only modification, if any happens).
Thanks for reading my thread!
« Last Edit: Thu, 01 October 2020, 23:33:43 by jmSur »
Offline czarjon
Re: [IC] The Brick 65
« Reply #1 on: Tue, 29 September 2020, 13:43:55 »
I had a choice between delving into the money-consuming hobbies of either Legos or Keyboards... yet here we are at the height of my interest. Definitely watching this closely!
Offline of_sam
« Reply #2 on: Tue, 29 September 2020, 13:45:13 »
I need to be launched into space.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline kumori
    • polartype
« Reply #3 on: Tue, 29 September 2020, 13:46:39 »
looks something that a child would always dream about... super nice
glwic, can't wait for improvements and updates :)
Offline Ja3_420
« Reply #4 on: Tue, 29 September 2020, 13:49:01 »
cool
Offline Zaprey
« Reply #5 on: Tue, 29 September 2020, 14:41:51 »
this is actually really cool!
Offline Jesus
« Reply #6 on: Tue, 29 September 2020, 15:18:06 »
I thought the mount65 was good, this is even better! fr tho this looks sweet GL with IC
Offline Nonnegaard
« Reply #7 on: Tue, 29 September 2020, 15:38:33 »
The artisan case is phenomenal.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Rayndalf
« Reply #8 on: Tue, 29 September 2020, 15:47:53 »
This is pretty silly, but also a really good design. The thick bezel and retro curves are great, and finding a way to make that bezel useful is genius.
Offline Demagine
« Reply #9 on: Tue, 29 September 2020, 16:24:18 »
Wait this is actually genius - I'd 100% buy!
Offline 3yatt
« Reply #10 on: Tue, 29 September 2020, 18:57:12 »
Ok. Now this is the first keep that's made me genuinely smile. Hoping this makes it to market as fcfs or unlimited because I need this.
Offline powwu
    • Discord
« Reply #11 on: Tue, 29 September 2020, 19:04:32 »
this is nice...I guess?
Offline jmSur
« Reply #12 on: Tue, 29 September 2020, 19:56:23 »
Will consider an unlimited quantity on limited time GB.
If many ppl participate on GB, I could provide more bricks on the market.
Offline KanyeMidEast
« Reply #13 on: Tue, 29 September 2020, 21:02:16 »
What about a small lube station or something where the brick is as a option? Not sure how many slots you could make in that space though..
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #14 on: Tue, 29 September 2020, 21:46:48 »
I need this in my life.  The possibilities...
Offline anticlockwise5
« Reply #15 on: Tue, 29 September 2020, 21:54:27 »
Ah, yes, I have already dove into Legos, might as well add another keyboard that will let me set my Lego Brick Headz on...
Sent from my SM-G981U1 using Tapatalk
Offline atlanticise
« Reply #16 on: Tue, 29 September 2020, 21:56:13 »
this is such a cool idea!
Offline heavyheaded
« Reply #17 on: Wed, 30 September 2020, 02:04:15 »
What bottom row layout options are available? The plate in the pic shows 3x1.25+1x6.25+2x1.5 and no 4x1.5+1x7 balanced row. Will the latter be an option?
Offline child
« Reply #18 on: Wed, 30 September 2020, 02:53:09 »
Generally I like the idea of replaceable bricks a lot. How are they attached to the case?
I support your decision to raise the brick area up. Even though your initial design looks better without the keys I guess that's not how most people will use it :)
I also would like to see the question about bottow row layouts (and layouts in general) being answered. Will split space be supported?
Offline jmSur
« Reply #19 on: Wed, 30 September 2020, 05:49:52 »
Not decided yet for bottom raw. Will consider 4x1.5u + 1x7u too
Offline jmSur
« Reply #20 on: Wed, 30 September 2020, 05:58:44 »
For attaching method not decided yet. I will use whether screws or magnets.
For bottom raw I am going to support two or three layers. Sorry for the split space.
Offline CastleKeyboards
  • UK Vendor
    • Castle Keyboards Website
« Reply #21 on: Wed, 30 September 2020, 11:09:29 »
Such a fun concept!
Offline Jippadox
« Reply #22 on: Wed, 30 September 2020, 12:35:44 »
Dumbest thing I've seen in a while, I absolutely love it!
Offline arydi
« Reply #23 on: Wed, 30 September 2020, 13:47:51 »
The name had me thinking this was going to be a keyboard without a PCB.
But I like it.
I want to see this concept with a clear case and the ability to attach bricks internally to dampen resonances and to diffract RGB light in complex patterns.
« Last Edit: Wed, 30 September 2020, 13:54:51 by arydi »
Offline kurly
« Reply #24 on: Wed, 30 September 2020, 14:27:16 »
made me nut in 3 seconds not gonna lie. very nice board
Offline catamscott
Re: [IC] The Brick 65 - Added more renders
« Reply #25 on: Wed, 30 September 2020, 15:31:24 »
seems like that thing is going to be a nightmare to machine. it's a unique idea but making the main case less complex might be a good idea
Offline jmSur
« Reply #26 on: Wed, 30 September 2020, 21:20:42 »
There are milling bits with rounded shape. All the rounded corners(with constant radius) can be easily cut through using those bits.
Offline OneWithNothing
« Reply #27 on: Thu, 01 October 2020, 01:39:12 »
Wow, great work. I don't think I've ever been so excited for a kit!
"When nothing remains, everything is equally possible."
Offline udller
« Reply #28 on: Thu, 01 October 2020, 07:39:16 »
i like the design with out the raised back. i think it would be cool to not have the arrows and extras keys not separated from the rest. ill probably try to buy two
Offline dc_in_sf
  • Old Bastard
« Reply #29 on: Thu, 01 October 2020, 14:03:13 »
Love the idea of this, and it's my favourite form factor so definitely interested.
Offline jmSur
« Reply #30 on: Thu, 01 October 2020, 23:22:35 »
Without the raised back, brick thickness should be 10mm. But as I am going to make a brick with function keys and a knob, I need that 20mm thickness. So there should be that raised back. But I am making The Brick 75 without the raised back(It's possible through higher layout and raised typing angle).
Offline The.Ryan.Gamer
Re: [IC] The Brick 65 - Final version
« Reply #31 on: Mon, 05 October 2020, 07:52:11 »
I'll be waiting on the price then decide. So far this looks good. I love that Gold color too
Offline ben56k
« Reply #32 on: Tue, 06 October 2020, 04:46:07 »
clearly interested. I wait for the 75 thread.
Offline zoo
    • zoo
« Reply #33 on: Tue, 06 October 2020, 12:15:03 »
looks interesting, but the fit of the lego brick with actual lego pieces seems like a potential place for error. would like to see a prototype of the brick with lego bumps and an image of lego pieces attached to it to evaluate how well they fit together
Offline beigeandbrown
« Reply #34 on: Tue, 06 October 2020, 15:35:44 »
Yeah that's a known problem with any type of lego clone product. lego is the gmk of bricks, their tolerances are crazy and most clones fall short. Makes me wonder if lego could do some sick abs keycaps.
Offline jmSur
« Reply #35 on: Wed, 07 October 2020, 17:57:08 »
Yeah will make the stud with some differnt radius.
But as the brick will be made of aluminum, there may be no problem of compatibility with the lego bricks.
« Last Edit: Wed, 07 October 2020, 20:11:51 by jmSur »
Offline Buster69
« Reply #36 on: Sat, 10 October 2020, 22:56:35 »
Any chance for a dark navy case?  :cool:
Offline qluboards
« Reply #37 on: Sun, 11 October 2020, 00:06:19 »
If no one in this community attaches an impractically large millennium falcon to this i will be disappointed
Offline Buster69
« Reply #38 on: Sun, 11 October 2020, 10:21:11 »
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #39 on: Mon, 12 October 2020, 02:25:06 »
Following  :)
Offline jmSur
« Reply #40 on: Tue, 13 October 2020, 20:51:31 »
Colours have not been decided yet.
Offline Darthbaggins
  • PC Cannibal
« Reply #41 on: Thu, 15 October 2020, 15:49:50 »
I can see my son stealing this from me if I were to get it.
Offline mrpetrov
« Reply #42 on: Thu, 15 October 2020, 17:44:54 »
neat idea and definitely interested
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #43 on: Thu, 15 October 2020, 17:56:33 »
10/10 would buy
Offline udller
« Reply #44 on: Thu, 15 October 2020, 19:31:34 »
name plate should have studs on it as well. just for consistency and the aability to have mini figs stand on that if some of the other things were put onto the actual backplate
Offline treeleaf64
    • treeleaf64
« Reply #45 on: Thu, 15 October 2020, 21:23:29 »
The brick
is good
Everyone must pay the cat tax
Offline DuellM
  • Keyboard Fatty
« Reply #46 on: Thu, 15 October 2020, 21:28:41 »
Any chance we could get a module with leds built in that we could program? https://www.amazon.com/dp/B07418XNJ2/ref=cm_sw_r_cp_api_i_8tqIFbW9CKQZ6
Offline Current Keyboards
    • currentkeyboards.com
« Reply #47 on: Thu, 15 October 2020, 23:26:00 »
Oh this is super rad. Always refreshing to see stuff like this.
Offline jmSur
« Reply #48 on: Fri, 16 October 2020, 02:49:12 »
Understood. I may make it as an option, if it is 'manufacturable'. But I can only put 1 raw of studs. Will it be still Ok to you?
Offline jmSur
« Reply #49 on: Fri, 16 October 2020, 02:53:02 »
hmmm. I am not an electronics engineer. Sorry. But I can make a brick that support arduino board and some big lcd(diy kit)
