Author Topic: [Question] Spacebar doesn't return to neutral position  (Read 2809 times)
Offline Qipz
« on: Wed, 30 September 2020, 08:39:36 »
Hey guys
Like the topic says, how do I fix this problem and what causes it?
It's probably the stabilizer but I don't see how to fix it.
Any input?
Pic of the stabilizer, which seems bent and the spacebar stuck all the way down.
Offline Tactile
Re: [Question] Spacebar doesn't return to neutral position
« Reply #1 on: Wed, 30 September 2020, 09:34:57 »
It might simply be a spacebar slightly warped or out-of-spec. Have you tried the action using a different spacebar?
REΛLFORCE
Offline yui
« Reply #2 on: Wed, 30 September 2020, 09:41:46 »
on the photo it looks like your space bar looks pretty warped yeah and on my 1st time i assembled my stabs backward, could that be it?
Offline Qipz
« Reply #3 on: Wed, 30 September 2020, 10:26:36 »
I tried 2 different spacebars and used both on 2 different boards, they both worked on my current board and didn't work on the board in the picture.
Offline Qipz
« Reply #4 on: Wed, 30 September 2020, 10:28:20 »
I have no clue, this was my first custom board and I had it assembled by someone in this community who, afaik, has made tons of boards.
Oh also, this is a GH60, I got it like 5 or 6 years ago or something and I just dug it out of the box wondering if I could fix up this problem I found back them
Offline Tactile
« Reply #5 on: Wed, 30 September 2020, 13:47:37 »
A straight-down photo without the spacebar might help.
REΛLFORCE
