Author Topic: [IC] GMK Stealth | Group buy is live + GIVEAWAY | Dec 16th - Jan 16th  (Read 253048 times)
Offline lakeboredom
Re: [IC] GMK Stealth | going live on December 16th! | Pricing announced
« Reply #300 on: Tue, 15 December 2020, 01:27:10 »
Woops! Looks like there are still necessary MODS in the alternate ALPHAS kit that should be in the BASE KIT. Boy that is embarrassing, glad I said something before this went into GB and you lost a bunch of people's interest because of such a tiny thing.
Offline FaKe_VirTual
    • Virtual Designworks
« Reply #301 on: Tue, 15 December 2020, 04:27:22 »
I'm working hard on the issue with the non-accented Esc and Enter in the last couple days. I think that I might have found a way to make it work.
Offline zxer
« Reply #302 on: Tue, 15 December 2020, 04:46:24 »
Nice one - this will definitely be a big plus for some folks that are not buying the dark alpha set.
I am still thinking about buying the dark set too - I'm considering just putting up with having to use the 5 ISO keys from the grey NORDEUK set. That may be too annoying though as will likely look a bit of a mess :)
Offline zxer
« Reply #303 on: Tue, 15 December 2020, 04:51:27 »
If you do a round two - have you considered doing grey versions of the keys that are black in the base set? To achieve a full set of grey. Not quite the vision of the set - but still nice to have as an option.
Offline zxer
« Reply #304 on: Tue, 15 December 2020, 05:21:48 »
Which keys do you mean?
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #305 on: Tue, 15 December 2020, 05:27:33 »
YES! Please do make it work, that would be awesome! /J
« Reply #306 on: Tue, 15 December 2020, 07:58:24 »
I had some long talks with my vendors and we came to the conclusion that we have to keep the kitting as is. We have to do it to avoid many inconveniences, trouble and risks that would occour with that, seemingly small, change.
With that being said, I really appreciate the feedback from you guys and you're definitely going to see those things being implemented into round 2 of stealth.
I'm excited to release Stealth tomorrow and I hope that you're too.
Offline mymeepo
« Reply #307 on: Tue, 15 December 2020, 08:30:33 »
It's okay. Thank you for trying and for the transparency. I will sit out on R1 and perhaps join this GB in R2. All the best!
Offline zxer
« Reply #308 on: Tue, 15 December 2020, 08:50:46 »
Out of interest - what were the problems that made the change not possible?
Offline nvh2092
« Reply #309 on: Tue, 15 December 2020, 09:51:40 »
To resubmit to gmk for a another quote for at least 2 kits: base and blackout. Gb will be surely delayed. I'll wait for a better R2 too.
Offline Jo_hannes
« Reply #310 on: Tue, 15 December 2020, 10:19:56 »
That's really too bad, but expected. Thank you for trying, anyways. /J
Offline zxer
« Reply #311 on: Tue, 15 December 2020, 11:30:42 »
I don't think a delay would be a terrible idea - and my thinking would be not to rush. Things have already moved pretty fast for this IC comparatively anyway.
However I can understand those involved being keen to stick to schedule.
Offline yukitoki
« Reply #312 on: Tue, 15 December 2020, 11:31:52 »
Ty for trying!
Offline konstantin
  • Formerly constexpr
« Reply #313 on: Tue, 15 December 2020, 21:29:51 »
Delaying a GB is not really an option (unless something genuinely catastrophic happens). GB windows are arranged months in advance, and each vendor only has a limited number of slots each month, so delaying a GB by a month or so would mess things up for everyone involved (including other sets that are scheduled to run later).
Re: [IC] GMK Stealth | Group buy is live! | Dec 16th - Jan 16th
« Reply #314 on: Wed, 16 December 2020, 07:46:05 »
WE'RE LIVE!
You can buy the set through the following vendors
For more information regarding Stealth in the future, head over to the GB Thread!
Offline PHYLO
« Reply #315 on: Wed, 16 December 2020, 09:53:38 »
Best looking GMK set ever that's primarily gray/black. Well done.
Offline joshuarubin
« Reply #316 on: Wed, 16 December 2020, 11:50:20 »
I'm already in and even got novelties and rama (matte) — and I never get novelties or rama. Great work! Q4 is a long way away...
« Reply #317 on: Wed, 16 December 2020, 12:36:15 »
If I can propose something for R2 please consider 2 separate base kits, one with the Anthracite alphas and one that is blacked out.
Just saw the pricing for base + alphas for this current one and it's just too expensive IMO (especially since I was another that wasn't a fan of the orange), as is often the case with these alpha add ons.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #318 on: Wed, 16 December 2020, 21:11:36 »
Congrats on the GB, Virtual, and all of your design partners. Incredible stuff.
Re: [IC] GMK Stealth | Group buy is live + GIVEAWAY | Dec 16th - Jan 16th
« Reply #319 on: Thu, 17 December 2020, 17:03:20 »
We're hosting a GIVEAWAY with CandyKeys to give a free Basekit back to you guys!
Just follow the link to the Groupbuy thread or click the link to the giveaway to find out more about it!
Offline Skok
« Reply #320 on: Thu, 17 December 2020, 20:55:17 »
wow very low profile
Offline chlorineequeen
« Reply #321 on: Fri, 18 December 2020, 16:32:49 »
Do you know when the rama keycaps with be available?
