Author Topic: Apple M0116 keyboard  (Read 2306 times)
Offline winteralfs
« on: Tue, 06 October 2020, 18:23:28 »
I had a question about reassembling a M0116 Apple Keyboard.  I can't get two serial ports back into the bottom tray. I was wondering how they were supposed to align them in the tray for proper reassembly? Thanks for your time!
« Last Edit: Tue, 06 October 2020, 18:34:14 by winteralfs »
Offline pixelpusher
Re: Apple M0116 keyboard
« Reply #1 on: Tue, 06 October 2020, 20:24:59 »
253127-0253129-1
Does this help?
Offline winteralfs
« Reply #2 on: Tue, 06 October 2020, 21:02:56 »
Thank you, that does help. If it is not too much trouble, could you take a photo with the top case removed, showing the inside orientation of the serial plates? Here is what I get when I try and replicate your orientation. They do not seem to fit in the case, even after pressing quite hard and jamming them in the spot? Here is a photo.
Offline pixelpusher
« Reply #3 on: Tue, 06 October 2020, 21:18:23 »
253134-0253136-1
Offline pixelpusher
« Reply #4 on: Tue, 06 October 2020, 21:21:59 »
Looks like you need to flip it over with the PCB towards the switches instead of the case back.
Offline winteralfs
« Reply #5 on: Tue, 06 October 2020, 21:48:27 »
