Author Topic: Flashed my keyboard and some keys are misaligned and others don't work.  (Read 1661 times)
Offline riceking
Have a gh60 which apparently is a not an official one and is also known as minila 64.
Initially, the board worked fine, however some keys like the right shift was binded to an arrow key. So I flashed it with a gh60 hex file. Then the board got messed up, when I press A it shows as S, S is D, D is F etc. Keys like the space bar don't work. I've tried following the guide specifically from the website bought, but still, nothing has changed. (https://mechboards.co.uk/shop/parts/satan-gh60-60-pcb/)
Re: Flashed my keyboard and some keys are misaligned and others don't work.
« Reply #1 on: Thu, 08 October 2020, 16:25:05 »
They're still selling these mislabeled?  How annoying...
Can't remember if they use the firmware for the DZ60 (rev 1 is different from 2 and 3) or KC60 firmware, I discussed it with someone with a similar problem a coupue of months back but searching my posts is not finding anything useful.  I'll have a proper look this time tomorrow if you've not got it sorted by then.
Offline shadowcelery
« Reply #2 on: Thu, 08 October 2020, 16:26:22 »
You should try flashing with the yd60 config. I believe theres been a lot of false advertising of 60% pcbs recently. I bought a dz60 and it would only work with yd60 flash.
