Author Topic: [HELP] Keyboard acts as if Ctrl+Alt are pressed...  (Read 2499 times)
Offline fade
« on: Sat, 17 October 2020, 16:17:13 »
Hey guys I wasn't really sure where to ask help for this but so often when I type, something happens and my keyboard goes into another mode/configuration where it types letters with accents or does certain things as if I am holding Ctrl + Alt. In order to disable it I have to spam press FN + Spacebar. I don't have any other languages installed/enabled. I can't figure out what is causing this, something toggles it on and it's driving me mad.
Any help would be greatly appreciated.
Discord: fade#0001
Re: [HELP] Keyboard acts as if Ctrl+Alt are pressed...
« Reply #1 on: Sat, 17 October 2020, 16:33:42 »
As it has an FN key I guess it's a custom board?  If so is the soldering good or was it your first build and a bit dodgy?  Is it in a metal case, any chance it's getting a static shock?
Offline fade
« Reply #2 on: Sat, 17 October 2020, 16:38:38 »
Yep it's a custom board. I ordered it off of kbdfans when I first got into all this and they built it for me before shipping it off. Soldering seemed fine on it when I checked, it has polycarbonate case.
I think it's something that toggles it on since I have to press FN + Spacebar to toggle it off. Perhaps something to with my VIA settings but I can't see anything weird there.
Discord: fade#0001
« Reply #3 on: Sun, 18 October 2020, 02:16:59 »
It doesn't sound like a useful feature so you would have had to set it up by mistake which surely would be hard (one extra key maybe, but not two) - can you share your VIA config?
See if you can get it to happen reliably while running Aqua Key Test, or run it when the paoblem happens.  You're looking for things like it only happening on keys near the mods or maybe keys in the same row or column.
What board is it?  You could try a different firmware to confirm that's the problem rather than something hardware.
Offline fade
« Reply #4 on: Mon, 19 October 2020, 19:27:45 »
I will try that thanks.
I am using the Polaris.
Discord: fade#0001
Offline fade
« Reply #5 on: Wed, 04 November 2020, 09:01:52 »
I have attacked my the json file for my via config I'm using for my Polaris. I can't get it to happen reliably... it just seems to randomly happen. I think you are right, it's happen because of the keys around the mods. I have to smash my spacebar button to make it go away (Fn + Spacebar make it go away faster) and then it just randomly happens again before I know it. This is driving me crazy so I've had to use my old keyboard.
Discord: fade#0001
