Author Topic: Build help  (Read 1746 times)
Offline Zontivity
Build help
« on: Wed, 21 October 2020, 17:05:00 »
Hi, Im not sure if this is the correct place to ask for help from people who know a lot more than me. Ive been looking at youtube and reading online but one problem exists. I live in sweden so I need ISO and would also want hotswap, size im pref 80% but I think im Ok all the way down to 60%(ive heard/read that the market is biggest at 60%)
Not sure what works with what... I found this https://www.aliexpress.com/item/4000590804514.html?spm=2114.12010610.8148356.3.1df422f4tELjJ4 but im guessing its not ISO since it doesnt say anything about it? I have orderd switches and lube so I should be fine on that front.
Im okey with paying more but I would pref not solder but its not out of the picture. Can someone help me find a compatible set that is in stock?
Thanks in advance for helping a new guy into the hobby!
Regards
Chris
Offline yui
Re: Build help
« Reply #1 on: Thu, 22 October 2020, 06:12:01 »
you are right this board does not support iso, one of the one that is always recommended for iso users > 60% is the GMMK, comes in TKL or 100% and support ISO and ANSI and can be ordered barebone if you have switches and caps, if you want 60% quite a few boards exist with iso support on chinese sites, the DZ60 for example does, cheaper examples i think exists.
Offline Zontivity
Re: Build help
« Reply #2 on: Mon, 26 October 2020, 16:27:10 »
Been looking more and more into TKL, could anyone recommend one with ISO support?
