Author Topic: [IC] Forged Carbon Fiber Plates for KBD67mkII  (Read 5296 times)
Offline FootFingers
« on: Sat, 24 October 2020, 11:45:41 »
Project Timeline:
Not The Carbon Fiber You Already Know
Forged Carbon Fiber is made from small chopped carbon fibers, this creates a unique and individual pattern for each plate.
No two plates are identical.
Lightweight and Strong
Each plate weighs roughly 41g, compared to brass weighing in at ~190g.
Inspired by Lamborghini Forged Composites
In 2008, Dr Paolo Feraboli created what would become Forged Composites for Lamborghini.
Taking this concept and applying it as a plate material creates unique patterns on each individual piece.
Difference between Forged Carbon and Carbon Fiber
The main difference is aesthetic. Forged Carbon has a marbled appearance compared to the typically Carbon Fiber woven look.
Forged also typically has a higher thread count, making the plate stronger.
In real world applications the feel and sound is very similar to traditional woven carbon fiber.
Video Examples:
Unfortunately I only had a phone to record these, so the quality is not as high as I would like here.
Forged Finish
Flex Test:
Typing Test:
A Finished Build:
Additional Information
Both hotswap and solder versions will be available.
Standoff holes are on the board for those that wish to use them, however they are not required and I personally do not use them.
Plates will be shipped from Ireland, and can be shipped to both EU and US.
Plates are between 1.5 and 1.6mm thick.
« Last Edit: Sat, 24 October 2020, 15:20:14 by FootFingers »
Offline FootFingers
Re: [IC] Forged Carbon Fiber Plates for KBD67mkII
« Reply #1 on: Sat, 24 October 2020, 11:46:57 »
Reserved
Offline Baka Bot
« Reply #2 on: Sat, 24 October 2020, 12:03:02 »
On the Podium I go(but I really want this)
Offline arkze
« Reply #3 on: Sat, 24 October 2020, 12:06:27 »
What od the thickness?
Wysłane z iPhone za pomocą Tapatalk
Offline FootFingers
« Reply #4 on: Sat, 24 October 2020, 12:34:29 »
It is between 1.5 and 1.6mm, added it to the main post now.
Offline FootFingers
« Reply #5 on: Sat, 24 October 2020, 12:39:00 »
edit
Offline cbbplanet
« Reply #7 on: Fri, 30 October 2020, 10:11:43 »
where are you getting the forged cf made if you don't mind me asking? Only because I've been looking to make some forged cf stuff for my car
