Author Topic: DIY Custom Silicone Dampener  (Read 19796 times)
Offline Sweet_Serendipity
    • Sweet Serendipity
« on: Fri, 30 October 2020, 18:52:29 »
So I've been lurking around in the Interest Checks and Group Buy sections and didn't know about this forum until now!  Anyway, I would like to share my experiment on making your own silicone dampener for a keyboard case.  Here's a link to the tutorial -->
t=1s
And here's a sound test -->
t=21s
Let me know what you guys think!  :D
Offline diamondogs
Re: DIY Custom Silicone Dampener
« Reply #1 on: Fri, 30 October 2020, 19:17:40 »
Why didn't I think of that! Great job   :thumb:
Offline fpazos
« Reply #2 on: Fri, 30 October 2020, 20:25:41 »
That's cool
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline hanya
« Reply #3 on: Fri, 30 October 2020, 21:45:16 »
You should make whole case with silicone.
PFU HHKB JP, Sanwa MA-TB38 trackball
Offline zammykoo
« Reply #4 on: Sat, 31 October 2020, 07:36:59 »
I had a similar thought to try something like this the other day. Nice to know that it works!
« Last Edit: Sat, 31 October 2020, 07:41:24 by zammykoo »
    • Sweet Serendipity
« Reply #5 on: Sat, 31 October 2020, 11:35:56 »
That's cool
Thank you, everyone!  ;D
    • Sweet Serendipity
« Reply #6 on: Sat, 31 October 2020, 11:38:04 »
That sounds kinda cool lol I might have to try that  :D
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #7 on: Sat, 31 October 2020, 14:10:49 »
Blown away by the results and quality of your video, I can’t wait to try it.
    • Sweet Serendipity
« Reply #8 on: Sun, 01 November 2020, 10:56:12 »
Thank you so much, and good luck with your project!  Let me know how it goes!
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #9 on: Sun, 01 November 2020, 13:29:48 »
What silicone mold kit did you use?  There’s so many to choose from  :eek:
« Reply #10 on: Sun, 01 November 2020, 14:27:59 »
There is an idea that I have been meaning to try where instead of having a keyboard "sandwich" be suspended on stand-offs or via a plate's edges, each switch's central "centre pin" would transfer its energy into a bump in a silicone "core" directly. I'm curious to what the sound profile of such a keyboard would be.
I've been thinking that perhaps for a very small keyboard with low-profile switches (think split 40% ergo with Kailh Choc), the PCB might provide enough rigidity alone so that the silicone core would be all that would be needed as both damper, feet and low case walls. This could also be a cost-effective way to make it a tented case.
One issue with this idea though is that a flexible case would not protect the components against blunt force — which a rigid case would. So perhaps some rigid part might need to be part of it anyway. Those horrible rolled-up silicone keyboards tend to have a box around the controller for this purpose.
I also think that maybe it would need to be co-moulded (double-shot) with two types of silicone: one shot with a harder type for feet and case sides, and another shot with a softer silicone for internal damping. Perhaps rigid parts could be laid into the casting in-between shots of silicone.
Both types of silicone would need to flow well, which means that you'd need two types of silicone: not just the same type with/without "thixotropic" additive — because that would make it thicker and more difficult to pour.
« Last Edit: Sun, 01 November 2020, 14:29:53 by Findecanor »
Offline ddrfraser1
  • RIP Neil
« Reply #13 on: Mon, 02 November 2020, 20:13:57 »
This is awesome. Will definitely try. Thanks!  :thumb:
    • Sweet Serendipity
« Reply #15 on: Mon, 02 November 2020, 20:20:22 »
Thanks for the compliment, good luck with your project!  Let me know how it goes!  ;D
Offline diamondogs
« Reply #16 on: Fri, 06 November 2020, 14:52:56 »
I think I'm actually going to try this. What kind of silicone did you used for the dampener? And how long would you say it takes to fully set?
    • Sweet Serendipity
« Reply #17 on: Sun, 06 December 2020, 16:24:18 »
Hey, sorry for the late reply!  I just used a generic silicone mold kit, which you can find in the video description :)  I would say it takes about 5 hours to fully cure.
Offline moxie keyboards
« Reply #18 on: Tue, 22 December 2020, 17:11:20 »
Very cool, will be trying this.
Offline idealape
« Reply #19 on: Wed, 06 January 2021, 05:59:35 »
Awesome! I did this too couple of months ago with my Keychron K6, just didn't get to finishing a video about it yet :P
Offline diamondogs
« Reply #20 on: Fri, 29 January 2021, 08:35:14 »
Glad to see your DIY solution to dampening the case is getting popular among the keyboard community!  :thumb:
Offline Bitdrive
  • Sup I’m new and takin a look around
    • @bitdrive Instagram
« Reply #21 on: Mon, 01 February 2021, 18:08:05 »
Yoo what, this is actually genius , I doubt I’ll try it but still what a great idea
Offline estux
« Reply #22 on: Sat, 16 October 2021, 03:59:09 »
I had this idea today and I came looking if someone else already did it, nice to see the results before trying!!
Thanks for posting it!
