Author Topic: Good Plate mount stabilisers  (Read 10732 times)
Offline phinix
« on: Tue, 03 November 2020, 16:21:45 »
Looking for a good plate mount stabs for few keyboards, for example DROP CTRL.
Which one are the best?
Offline MilkTea_QAQ
Re: Good Plate mount stabilisers
« Reply #1 on: Wed, 04 November 2020, 09:53:42 »
Evergilde
Offline phinix
« Reply #2 on: Wed, 04 November 2020, 10:13:23 »
Evergilde
Where can I buy them? Apart from kprepublic.
Offline MilkTea_QAQ
« Reply #3 on: Wed, 04 November 2020, 10:16:23 »
Evergilde
I’m in Asia so I can’t really answer your question.... but they are really good plate mount stab! Just not really sure if they will perfectly fit drop’s keyboard.
Offline Darthbaggins
  • PC Cannibal
« Reply #4 on: Wed, 04 November 2020, 13:28:48 »
So far only place to find them in plate mount is on KPRepublic/Alibaba/Ali-express/BangGood.  Every e-tailer here stateside and in EU looks to mainly sell the PCB Screw-ins in other brands and only the Cherry Plate mounts.
Offline phinix
« Reply #5 on: Wed, 04 November 2020, 14:18:14 »
Would these be ok?
It says genuine cherry stabs.. https://candykeys.com/product/genuine-cherry-mx-stabiliser-pack-plate-mount
« Last Edit: Wed, 04 November 2020, 16:46:36 by phinix »
Offline treeleaf64
    • treeleaf64
« Reply #6 on: Wed, 04 November 2020, 16:46:09 »
I didnt know everglide make plate mount stabs
Cherry plate mount are p good
Everyone must pay the cat tax
  • PC Cannibal
« Reply #7 on: Wed, 04 November 2020, 16:47:21 »
Would these be ok?
(Did you get my PM about CM keyboard?)
Yup thanks for that I PM'd back as well  :thumb:
The Cherry ones will work/ serve their purpose
