Author Topic: [IC] [v0.9] Inexpensive Computers NumpadA: QMK programmable, open source numpad  (Read 3673 times)
Offline anna328p
  • Formerly 'dkudriavtsev'
    • Inexpensive Computers
Interest Check Form
Hello GeekHack,
I have been working on a numpad/macro-pad that fits a niche I haven't seen filled yet: open-source PCB, support for the QMK firmware, and no microcontroller board necessary.
The latest prototype, v0.9, adds per-switch LED support, RGB backlighting, and has a smaller PCB. It is also Certified Open Source Hardware!
v0.9 images:
Render of board front
Render of board back
v0.5 images:
Assembled
Interest Check Form
GitHub Repository
USB numpad with standard layout, extra keys, macro support, in-switch LEDs, and RGB backlighting. Will support the QMK firmware on launch. Requires 21 switches (MX, Alps, Choc), 21 keycaps, and a case.
STM32F103C8T6 microcontroller, USB-C port. Access the bootloader by holding backspace (top-right key) while plugging in the board.
Features include:
  • Full n-key rollover
  • Standard PC numpad layout for keycap compatibility, with an extra row spaced 1/3u up.
  • Fully programmable, with macro support and Fn key.
Depending on interest, group buy may include four different types of cases:
  • FR4 sandwich-style plates
  • Stacked acrylic case and plates
  • Machined aluminum case and plates
  • 3D-printed plastic case and plates
All of the case files will be released under open-source licenses, so you can manufacture your own case variants like wood cases.
The price is targeted at around $25-30 for the PCB with all components. This may change depending on the features requested by the community.
Interest Check Form
Offline Nonnegaard
Reserved
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
