Author Topic: Hey y'all newbie alert  (Read 1412 times)
Offline ShawnyBoii
« on: Sun, 08 November 2020, 20:51:03 »
Hey everyone!
I'm excited to be here.  I got introduced to custom MKBs through a random Taeha Types Polaris build video a couple of days ago, and decided this would be a cool project to pursue. I recently built my gaming pc and that was a really fun project to do, and I hope this is even better (yes ik this is going to run my wallet).
I know the basic components of a keyboard, but know nothing about the various different options, which I hope to learn here.  I want to build a budget 60% keyboard and the only component I've decided on so far are Gateron Milky Yellow switches.  Amped to be a part of this community and thank you for welcoming me!
« Last Edit: Sun, 08 November 2020, 20:52:42 by ShawnyBoii »
Offline Thatslowkeeb
Re: Hey y'all newbie alert
« Reply #1 on: Sun, 08 November 2020, 22:35:28 »
Welcome! Switches are always a great place to start seeing as there are so many to choose from & are needed no matter what build you choose to go with.
I think the next step should be looking into cases! You can go with something simple & readily available or possibly find something that peaks you interest in an upcoming or active group buy!
This will allow you to then look into compatible PCB’s & plates to finalize your choice of components for your build.
Best of luck, I look forward to seeing it come together!  :thumb:
