Author Topic: Differences between Realforce 86U and 87U  (Read 11138 times)
Offline dan_public
« on: Wed, 28 July 2010, 22:31:30 »
Now that I've gotten the feel of a decent mechanical keyboard (I now have two "Majestouch Tenkeyless Tactile Touch" Brown Cherry keyboards: http://www.elitekeyboards.com/products.php?sub=filco_keyboards,majestouch_87key&pid=fkbn87meb), I've been bitten by the bug and have gained a decent understanding of the art and magic of mechanical keyboards.   That is, except for one piece of wisdom - what the heck is the difference between the Realforce 86U and 87U?
Here's the 86U: http://www.elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless&pid=rf_se0500
I can find this answer anywhere.
Thanks,
Dan.
Offline maxlugar
« Reply #1 on: Wed, 28 July 2010, 22:49:15 »
Quote from: dan_public;207268
Thanks,
Dan.
Blue LEDs.  The 87U has Blue LEDs in the key caps for CAPS Lock and NumLock.
Emperor of the IBM 84-key AT Model F Darkside
Offline phoenix
« Reply #2 on: Thu, 29 July 2010, 00:22:12 »
The 86u lets you swap Ctrl and Alt, so you can press Ctrl with your thumb. This could be really useful depending on which one you use more frequently.
Offline ironman31
« Reply #3 on: Thu, 29 July 2010, 00:47:50 »
Quote from: phoenix;207357
dont you mean control and caps lock...?
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline maxlugar
« Reply #4 on: Thu, 29 July 2010, 00:49:26 »
Thanks,
Dan.
The missing key on the 86U (vs. the 87U) iw the right hand side Windows key on the bottom row.
Offline itlnstln
« Reply #5 on: Thu, 29 July 2010, 06:53:57 »
Quote from: ironman31;207376
I believe this is the case.  Also, the 86U does not have the virtual numpad; it's more like the Filco Tenkeyless this way.
Offline ch_123
« Reply #6 on: Thu, 29 July 2010, 07:07:08 »
IIRC, the 86U has no lock lights.
Offline javifast
« Reply #7 on: Thu, 29 July 2010, 07:43:23 »
And I think the 86U model have some 30g keys, and on the 87U are 35g...
Too many keyboards....
Offline phoenix
« Reply #8 on: Thu, 29 July 2010, 10:59:36 »
Quote from: itlnstln;207437
No, I mean Ctrl and Alt, unless Elitekeyboards made a mistake on their website:
http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless&pid=rf_se0500
Offline ironman31
« Reply #9 on: Thu, 29 July 2010, 11:22:24 »
ok, sorry, I thought you meant the actually keycaps. Yeah, the dip switches do make that possible.
Keyboards:
Pointing Devices:
Offline dan_public
« Reply #10 on: Thu, 29 July 2010, 19:10:18 »
Thanks.   It sounds like there's nothing of significance (for me) between the two.   I'm happy with my two Filco's.   Of course, it might be nice to try out an 86U...  :yo:
Dan.
Offline sam113101
« Reply #11 on: Thu, 29 July 2010, 22:35:38 »
somebody knows if the 87U will be back on elitekeyboard some day*?
it seems better than the 86U to me, with the LEDs, the pseudo-numpad, etc…
Hoping to hear from you again, your dearest friend, sam113101.
Offline didjamatic
« Reply #12 on: Thu, 29 July 2010, 22:44:30 »
Quote from: javifast;207449
Right you are.  I got a 103u from elite that had this configuration, many argue with me because it's supposed to be 35/45/55 but that's what I got.  The Realforce 101 was a 30/45/55 board and I wondered if my 103u was mistakenly fitted with 101 domes.
I never noticed the 86u was like that.  For me, I strongly prefer 35/45
Offline itlnstln
« Reply #13 on: Fri, 30 July 2010, 06:54:07 »
The box for my 103U says 30/45/55 (Elitekeyboards shows the same).  Maybe I didn't quite get what you were trying to say.
Offline itlnstln
« Reply #14 on: Fri, 30 July 2010, 10:13:06 »
Ah, got it.  I thought it was a little odd that they would drop the weight all the way down to 30g. on those keys.
