Author Topic: Do you use an adapted localized ANSI layout?  (Read 1532 times)
Offline markanini
« on: Tue, 10 November 2020, 02:54:44 »
Share yours here. To start off here are some I found on the web.
« Last Edit: Tue, 10 November 2020, 08:36:46 by markanini »
Offline markanini
Re: Do you use an adapted localized ANSI layout?
« Reply #1 on: Tue, 10 November 2020, 17:45:55 »
Here's some more.
Offline Entropia
« Reply #2 on: Wed, 11 November 2020, 10:55:18 »
I have adapted my keyboard, but not the legends on my keycaps, but the functions of many keys and keys combinations (AutoHotkey). I'm using a 1800 layout. Now, some of the keys I never used before have useful functions, and I have lots of key combinations which are easier to remember, and even keys and combinations that depends on the active program or for instance, the fact that a file is selected or not, as well as keys with double functions (single press or hold).
LControl + LAlt + ESC:
Screensaver and computer lock
LControl + LAlt + F4:
Force-close web browser
F2:
Rename without prompt
F6 (hold):
Extract external hard drive
F7:
Open up Notas.txt with Sublime Text
F7 (hold):
Extract pendrive
F8:
Enable / disable StrokeIt (mouse gestures)
F9:
Run, restore or minimize web browser
F10:
Run Thunderbird
F12:
Close all Explorer windows
F12 (hold):
Shutdown computer
LControl + LAlt + F9:
Upload selected text to server
LControl + LAlt + F10:
Upload tabs urls to server
LControl + LAlt + F11:
Open up text file from server
LControl + LAlt + F12:
Edit text file from server
Shift + Backspace:
Up in the directory tree
Ins:
Printscreen
Scrolllock / Pgup:
Run, restore or minimize foobar2000
Pause / Pgdn: (hotkey global en foobar2000):
Pause music in foobar2000
LControl + LAlt + `
Run Mediatools (custom set of hotkeys)
LControl + LAlt + U:
Write domain url / upload selected file to server
LControl + LAlt + P:
Write password
LControl + LAlt + E:
Write e-mail address
LControl + LAlt + L:
Write horizontal line
LControl + LAlt + B:
Toggle low brightness
RControl / Appskey:
Define / open menu with shortcuts to folder and apps (custom program)
LWin / RWin / RControl:
Open up with Sublime Text / extract rar or zip / open up with Photoshop / open up with Sublime Text / run url from Sublime Text / homepage
RAlt: Cycle tabs
N (hold): Ñ
U (hold): Ü
Numpaddot: Decimal comma
Delete: Numlock
Numlock: Delete
LControl + A
Select all with file explorer
RAlt + O:
º = primerO
RAlt + A:
ª = primerA
RAlt + E:
€ = Euro
RAlt + U:
Ü = U with diaeresis
RAlt + C:
Ç = Cedilla
RAlt + L:
£ = Pound
RAlt + Y:
¥ = Yen
RAlt + period:
• = bullet point
RAlt + hyphen:
→ = arrow
RAlt + 2:
² = square
RAlt + 3:
³ = cube
RAlt + G:
° = degree
RAlt + M
½ = half
RAlt + B
  = no-Break space
RAlt + T:
© = copyrighT
RAlt + R:
® = Registered
RAlt + H:
♥ = Heart
RAlt + N:
♫ = musical Note
RAlt + *:
★ = star
RAlt + S:
☺ = Smiley
RAlt + V:
✓ = V check
RAlt + X:
× = multiplcation
RAlt + D:
÷ = division
Modified as non-dead keys:
« Last Edit: Wed, 11 November 2020, 11:02:27 by Entropia »
