Author Topic: [GB] HONEYBOARD 60% - STORMTROOPER WHITE CERAKOTE - Closed  (Read 8454 times)
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« on: Thu, 12 November 2020, 09:18:42 »
StormTrooper White HB60% By Mtb Keys
UPDATE - Jan 4 2021
Unfortunately, there was a QC problem with the boards at Cerakote. There was a color mismatch between the lid & base, and the Cerakote guys need to re-spray. He is on it and hopes to bead blast tonight and re-spray tomorrow. We have all the hard wear and packaging ready and will start shipping out as soon as every thing passes QC.  Sorry for this and thank you all for your patience.  - Matt
Hello everyone!  We are pleased to announce the GB for the Honeyboard 60% StormTrooper White is now open.
It will run from Monday the 9th - 10:00 am (PT) to Monday the 16th, or untill Unit Cap is met.
Unit Cap is 45. - STILL SOME AVAILABLE!
GB LINK - mtbkeys.com/shop
Geekhack IC - https://geekhack.org/index.php?topic=109001.msg2978590#msg2978590
Reddit IC - https://www.reddit.com/r/mechmarket/comments/jjrnr6/ic_honeyboard_60_stormtrooper_white_cerakote/
Reddit GB - https://www.reddit.com/r/mechmarket/comments/jr2fmm/gb_honeyboard_60_stormtrooper_white_cerakote/
Specifications & What to Expect:
  • Base & Lid - Glass bead blasted & Cerakote StormTrooper White Semi Gloss
  • Switch plate - 1.5mm thick Aluminum - Your Choice: Glass bead blasted & Cerakote  Black Semi Gloss- or Brushed Anodized Black
  • Sandwich mount with O-rings.
  • 4 degree typing angle.
  • PCB - not included
  • Honeycomb pattern on the inside & on the back face .020" (.5mm) deep.
  • $310.00 USD + shipping - 45 units cap for a shipping date in mid to late December 2020
  • High quality in-house machining - made in Canada
Switch Plate Layout Choices:
  • Universal
  • ANSI
  • Tsangan
  • HHKB
  • Winkeyless
We have started production and we estimate that we will start shipping in mid to late December 2020.
Extra Plates NOT available for this round, but the DXF or STEP files will be available for free download from our website.
GB Rules - Cancellations: as this is a very limited GB, we will not be accepting any cancellations.
Join our Discord for updates! https://discord.gg/fUyWvek
Thanks,
Matt  :D
« Last Edit: Mon, 04 January 2021, 14:06:15 by MattMTB »
Offline KFMan
Re: [GB] HONEYBOARD 60% - STORMTROOPER WHITE CERAKOTE
« Reply #1 on: Thu, 12 November 2020, 11:52:07 »
That is fantastic. I can't wait for my board. :) :)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #2 on: Thu, 12 November 2020, 12:50:31 »
This looks so classy. Hopefully tsangan is 1.5 1 1.5 7 1.5 1 1.5 bottom row with 1.75 right shift.
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #3 on: Thu, 12 November 2020, 13:56:47 »
Thanks for the good vibes! Yes, that's tsangan.
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #4 on: Fri, 13 November 2020, 08:59:43 »
We've started production! :thumb:
Offline azzipa
« Reply #5 on: Fri, 13 November 2020, 11:43:19 »
Stoked for this. Order already in and my PCB just showed up, so I think I have all parts on hand.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #6 on: Fri, 13 November 2020, 12:10:22 »
Ooooh, I didn't notice it doesn't come with a PCB. What is suggested?
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #7 on: Fri, 13 November 2020, 15:25:56 »
The DZ60 from KBD fans is what we designed the case around. But also the AN-C 60 from cannon keys works too. I guess any 60% that has the USB on the left side.
The measurements you would want to look for is 125mm from the center of the pcb to the center of the usb.
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #8 on: Sat, 14 November 2020, 18:09:29 »
Still a few available - Closes Monday.
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #9 on: Mon, 16 November 2020, 08:54:28 »
GB Closes Today - a still a few available...
Offline MattMTB
  • MTBkeys
    • MTB Kyes
« Reply #10 on: Mon, 04 January 2021, 14:03:25 »
Update -  Unfortunately, there was a QC problem with the boards at Cerakote. There was a color mismatch between the lid & base, and the Cerakote guys need to re-spray. He is on it and hopes to bead blast tonight and re-spray tomorrow. We have all the hard wear and packaging ready and will start shipping out as soon as every thing passes QC.  Sorry for this and thank you all for your patience.  - Matt
