Author Topic: Looking for round keyboard aesthetic  (Read 4934 times)
Offline iluvdylan123
« on: Mon, 16 November 2020, 13:17:17 »
Hi, new to the community here! I was wondering if you guys knew of some rounded edge boards like the Space65, Dolores, & L7-65%, & KARA that come in white or light colors? I've been searching for some decently priced ones (under $300) but it's a bit hard to find
Offline Newsbusel
Re: Looking for round keyboard aesthetic
« Reply #1 on: Sun, 13 December 2020, 12:56:53 »
Sadly, many of those rounded edge keyboards are in the 350 and higher range, but the future may change. I check the interest check page frequently so if you're in the market, look there
Offline jamster
« Reply #2 on: Sun, 13 December 2020, 19:25:42 »
This might not be what you are looking for (MX, 'custom' looking 65%), but one option to consider would be a Realforce 87U. Rounded and 80s-looking, light beige.
IMO it's got better switches than anything 'custom', but it's also far less suited for personalisation, and it's TKL.
