Author Topic: created keycaps  (Read 1783 times)
Offline mithkey
created keycaps
« on: Tue, 17 November 2020, 21:53:12 »
Hi every one,
im newbie in here, can i ask u some question, if i have abilities make a set keycap by my design, can i collab with geekhack to make it real?
thank you
« Last Edit: Fri, 20 November 2020, 04:30:34 by mithkey »
Offline yui
Re: created keycaps
« Reply #1 on: Wed, 18 November 2020, 01:20:40 »
geekhack is only a forum where enthusiast share ideas and announce projects, depending on what you want to do you would need to go to GMK/SP/etc... to make full keysets or if you want to make artisan caps 1st make some prototypes and ask to be let part of the artisan marketplace.
if you need help with making stuff there is the making stuff together subforum but geekhack do not have any manufacturing abilities in itself.
and no everyone is native english here so if you could use complete words it would help with getting helped, as using "u" and "creat" will not work with translator and makes you look lazy.
Offline mithkey
Re: created keycaps
« Reply #2 on: Fri, 20 November 2020, 04:28:12 »
okay thank you so much, i'm a lazy guy =))
