Author Topic: SK87 bluetooth keyboard kit  (Read 19308 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 18 November 2020, 01:11:44 »
SPECS
Everglide
Layout: Fixed 87-key (TKL)
Case material: ABS
Keycap material: Dye-subbed PBT
Plate-mount stabilizers
Adjustable rubber feet
1500 mA lithium ion battery
Tray-sandwhich mount
Connectivity: Bluetooth or USB-C
Bluetooth version: Bluetooth 5.0
Detachable USB-C port
Kailh Hot-swappable switch sockets (5-pin compatible)
Full SMD RGB LEDs
Full anti-ghosting
Felt layer between PCB and plate to reduce noise
Programmable with driver software
Support for music rhythm mode
PURCHASE
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: SK87 bluetooth keyboard kit
« Reply #1 on: Wed, 18 November 2020, 01:12:03 »
Offline phinix
« Reply #2 on: Thu, 20 May 2021, 11:41:17 »
SPECS
Everglide
Case material: ABS
Full SMD RGB LEDs
Full anti-ghosting
PURCHASE
Where can I buy south facing version?
All I find is north facing switch version.
Offline MIGHTY CHICKEN
« Reply #3 on: Thu, 20 May 2021, 11:46:39 »
I remember this coming up where some people asked around different stores for south vs north-facing(Pretty Recent). It appears the factory only makes north-facing PCBs now, but some(I don't know which) stores might still have south-facing stock. Product images and descriptions might be outdated so you'll have to ask the seller if it is actually north or south.
Offline phinix
« Reply #4 on: Thu, 20 May 2021, 11:52:07 »
I see. So I hope KPrepublic will answer here cause I want to buy from their website.
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #5 on: Mon, 24 May 2021, 03:14:44 »
The factory only has the north-facing LED now.
we already updated the picture on the page.
