Author Topic: [IC] Cornelius - Gasket mounted 40% column staggered keyboard  (Read 41193 times)
Offline foostan
« on: Sat, 21 November 2020, 10:11:01 »
Cornelius
Hello, everyone.
I'm foostan, let me introduce about the new own product "Cornelius".
My main product are Corne Keyboard series those Open Source shared at https://github.com/foostan/crkbd.
Cornelius is a new keyboard designed based on the concept of the Corne Keyboard.
INTEREST CHECK FORM (CLOSED)
UPDATE
  • 11/21/2020, Create this post
  • 01/06/2021, Add new prototypes photos
  • 01/06/2021, Update Vendors and Pricing
  • 02/23/2021, Update Vendors, Pricing and Result of IC
  • 02/26/2021, Update Vendors
CONCEPT
  • Compact with minimal number of keys required
  • Ergo-like layout to ease the burden of the body
  • Gasket mounted structure with a focus on the typing experience
DETAILS
  • Typing angle: 6.5deg
  • Mounting type: Gasket mount
  • Materials: Anodized(or E-White) Aluminum Body, Anodized Aluminum(or Polycarbonate) Plate, E-Black Brass Weight, PORON Gasket and Foam
  • PCB: USB-C, hotswap or soldering PCB, configurable with QMK and VIA
COLORS
  • Body: Black, Dark Gray or E-white
  • Plate: Black, Purple, Burgundy, Blue or Polycarbonate
Renders
Photos
Compare Dark Gray with MacbookPro Space Gray
VENDORS
PRICING
Around $430 (E-white: +$30)
Number of UNITS
TBD
PHOTOS
RESULT of IC
Q: What color would you choose for the case? (Multiple Choice)
A: E-White: 48.7%, Black: 43.6%, Dark Gray: 32.4%. The other answers are all less than 1%. As planned, the case in three colors: Black, Dark Gray, and E-White.
Q: Which plates would you choose? (Multiple Choice)
A: Anodized Aluminum Black: 50.2%, Polycarbonate: 36.0%, Anodized Aluminum Burgundy: 21.8%, Anodized Aluminum Purple: 16.7%, Anodized Aluminum Blue: 12.7%. The other answers are all less than 1%. As planned, the plate in four colors: Black, Purple, Burgundy, Blue or Polycarbonate.
Q: Which PCB would you choose? (Multiple Choice)
A: Hotswap PCB: 73.4%, Soldering PCB: 35.4%. The Hotswap PCB will be included by default as planned, and the Soldering PCB can be purchased as an optional extra.
And other questions or requests
Q: Brass plate maybe?
A: Brass is not included in the options. I will release the plate data.
Q: To be OSS
A: It will not be released as open source. I will release the plate data, and may release the PCB as well.
Q: Is it possible to use a keycap puller without scratching the case?
A: No problem. There is a standard margin between the case and the keycap.
Q: Rotary encoder support in the outer bottom corners.
A: I do not intend to add a rotary encoder to this design.
Q: Option for weight color
A: I'm sorry. Weights are for E-Black only. Please understand that this is for risk hedging.
Q: Please include VIA Configurator support.
A: coming soon.
Q: Is it an option just to buy the PCB and key-switch plate?
A: The PCB and plate can be purchased as options.
CONTACT
« Last Edit: Thu, 25 February 2021, 10:19:04 by foostan »
Offline Freeaboo
Re: [IC] Cornelius - 40% column staggered keyboard
« Reply #1 on: Sat, 21 November 2020, 10:15:40 »
I like.
Offline sloth.
  • Corne gang
Re: [IC] Cornelius - Gasket mounted 40% column staggered keyboard
« Reply #2 on: Sat, 21 November 2020, 10:21:28 »
Me and my three cornes are soooooo in  :eek:
Offline eightbitraptor
« Reply #3 on: Sat, 21 November 2020, 10:23:43 »
I'm in, My Cornes need this
Offline Puree
« Reply #4 on: Sat, 21 November 2020, 10:27:24 »
I am in :-*
Offline zhon
    • my website
« Reply #5 on: Sat, 21 November 2020, 10:39:31 »
I'm in love with it, totally sold on my part! GL with the project, and I hope for an EU proxy :)
Offline JoltFX
« Reply #6 on: Sat, 21 November 2020, 11:19:28 »
Very intrigued will be following
“𝙁𝙖𝙞𝙩𝙝 𝙞𝙨 𝙩𝙝𝙚 𝙗𝙞𝙧𝙙 𝙩𝙝𝙖𝙩 𝙛𝙚𝙚𝙡𝙨 𝙩𝙝𝙚 𝙡𝙞𝙜𝙝𝙩 𝙬𝙝𝙚𝙣 𝙩𝙝𝙚 𝙨𝙠𝙮 𝙞𝙨 𝙨𝙩𝙞𝙡𝙡 𝙙𝙞𝙢.”
Offline donny_pete
« Reply #7 on: Sat, 21 November 2020, 11:35:49 »
This might have to be the first 40% I will add to my collection
Offline gwillad
« Reply #8 on: Sat, 21 November 2020, 11:44:24 »
love to see a new project from foostan, and for a premium case for corne-esque layout. Curious why not split though? Save on production cost?
Offline darthcapn
« Reply #9 on: Sat, 21 November 2020, 11:49:34 »
Looks awesome! I am in!!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Pontus
« Reply #10 on: Sat, 21 November 2020, 12:32:29 »
Very interesting!
Offline prkns
  • Fourteen
    • Fourteen Keyboards
« Reply #11 on: Sat, 21 November 2020, 12:40:27 »
Definitely in on this 🙌
Offline treeleaf64
    • treeleaf64
« Reply #12 on: Sat, 21 November 2020, 13:05:56 »
Treeleaf approved good job
Everyone must pay the cat tax
Offline martensson
« Reply #13 on: Sat, 21 November 2020, 14:33:35 »
I need this but in 50% in my life, looks awesome!
Offline krautcat
  • local the flammable man without identity
« Reply #14 on: Sat, 21 November 2020, 14:34:09 »
Oh my god yes yes foostan please yes yes please please
« Last Edit: Sun, 22 November 2020, 11:53:05 by krautcat »
Offline chaoskills08
« Reply #15 on: Sat, 21 November 2020, 14:41:51 »
I adore this! Really happy to see more columnar premiums. It's a little wide for me but just wanted to announce my excitement for this project :D
Offline Ireris
  • p a i n
« Reply #16 on: Sat, 21 November 2020, 14:53:24 »
Me likey
Sent from my Pixel 5 using Tapatalk
Offline parablol
« Reply #17 on: Sat, 21 November 2020, 23:09:42 »
That is one absolutely beautiful keyboard
Offline foostan
« Reply #18 on: Sun, 22 November 2020, 01:18:27 »
The main reason is that I wanted to challenge myself a bit differently than Corne. Yes, there was also the issue of cost.
Offline Dafraz117
« Reply #19 on: Sun, 22 November 2020, 09:12:07 »
Wow this might be the first 40% I join. It’s gorgeous.
Offline Macmutant
« Reply #20 on: Sun, 22 November 2020, 11:57:57 »
This looks so good! Will there be ESD protection?
Offline zoo
    • zoo
« Reply #21 on: Sun, 22 November 2020, 14:45:05 »
Nice! The engraved typemark on the weight could use some margins
Offline wolverine92
« Reply #23 on: Sun, 22 November 2020, 15:04:41 »
What key cap set is that in the first picture? Looks MT3, possibly a mix of two sets??
Offline FlitzDeelman
« Reply #24 on: Sun, 22 November 2020, 15:25:43 »
Have you considered tenting the two halves?
I’m interested regardless of the answer.
Offline Ireris
  • p a i n
« Reply #25 on: Sun, 22 November 2020, 15:52:22 »
Would engravings or symbols on top make it look better ?
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #26 on: Sun, 22 November 2020, 16:16:25 »
ok im down
Offline foostan
« Reply #27 on: Sun, 22 November 2020, 18:36:34 »
There is not it on the prototype now, but I'll update a PCB.
Yes, modifier keys are MT3 Susuwatari and alpha keys are MT3 Black on White.
Is it like this? https://twitter.com/foostan/status/1217986507694198785
I didn't adopt this one simply because it wasn't to my liking.
Sorry, what do you mean?
You want engravings on the top of the body, right?
Offline Ireris
  • p a i n
« Reply #28 on: Sun, 22 November 2020, 18:38:26 »
I just have bad eyes , didn't quite see the engravings on the weight
Offline v683
« Reply #29 on: Mon, 23 November 2020, 22:07:48 »
Welcome Foostan, I'm definitely in on this. Tenting would be very good for ergonomics, especially for your wrists, and it will look good too: https://geekhack.org/index.php?topic=107031.0
« Reply #30 on: Tue, 24 November 2020, 03:56:07 »
Yup, that’s exactly what I was thinking. Similar to Gok’s tented Alice, the Type K.
Your answer is good enough for me, it’s your board, and your prerogative to build what you like.
Thanks for answering! Like I said, I’m interested anyway.
Offline easy_rider
« Reply #31 on: Fri, 11 December 2020, 03:18:54 »
looking good!
Offline hottrout
  • I'd Hit Dat Key
« Reply #32 on: Fri, 11 December 2020, 06:15:19 »
Very interesting indeed.  Watching with excitement.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline foostan
« Reply #33 on: Tue, 05 January 2021, 10:35:29 »
I will close the Interest check form soon and share the results at here.
Offline Tom Sparrow
  • This is the way!
    • More stuff from me
« Reply #34 on: Tue, 05 January 2021, 13:18:46 »
This makes me want a 40%. I have to justify the price for me tho.
Offline i luv chuletas
« Reply #35 on: Tue, 05 January 2021, 14:18:41 »
Oh this is sexy.
Will be keeping an eye out for this project!
Offline Keyjus
« Reply #36 on: Sat, 09 January 2021, 05:24:01 »
Omg this looks soo good!
Sent from my SM-G975F using Tapatalk
Offline Donosir
« Reply #37 on: Sun, 10 January 2021, 21:21:25 »
This is the first 40% I've seen that I'm trying to figure out how to convince my wife to let me buy. Good Job!
Offline kajahtaa
« Reply #38 on: Thu, 04 February 2021, 23:47:14 »
Love this, Would join.
Offline Groom
« Reply #39 on: Fri, 05 February 2021, 11:39:47 »
like the layout ,this board looks mini nice
Offline baobaozi
« Reply #40 on: Tue, 23 February 2021, 00:00:06 »
My wallet is crying out in pain
I forgot to ask in the IC form; is there RGB? Would love some RGB
« Last Edit: Tue, 23 February 2021, 18:32:17 by baobaozi »
Offline to1ne
    • Personal webpage
« Reply #41 on: Wed, 24 February 2021, 03:39:37 »
I never thought I'd say this: I might be willing to pay $430 for this.
Offline spelunkpunk
« Reply #42 on: Wed, 24 February 2021, 05:00:26 »
this looks SO good can't wait for the group buy. the photos of the white burgundy one have sold me
Offline harlekein
« Reply #43 on: Wed, 24 February 2021, 07:51:00 »
Oof that price. Going to need some time to convince myself, because this looks amazing.
Offline foostan
« Reply #44 on: Thu, 25 February 2021, 10:23:17 »
Sorry, RGB is not supported.
Offline hkiri
« Reply #45 on: Thu, 25 February 2021, 14:14:57 »
Oh, awesome, Splitkb as EU Vendor. Thank you!
« Reply #46 on: Sun, 14 March 2021, 13:46:26 »
Any photos or renders of this beautiful keyboard and the polycarbonate plate option?
Offline sartrism
« Reply #47 on: Tue, 23 March 2021, 22:41:48 »
A bit late but the photo of prototype was on foostan's Discord channel. He said it's basically transparent so looks like black because of the color of PCB.
Offline Fenlair
« Reply #48 on: Tue, 27 April 2021, 08:42:11 »
i'm heartbroken I missed this group buy  :( - looks so awesome!
Offline treeleaf64
    • treeleaf64
« Reply #49 on: Tue, 27 April 2021, 09:21:21 »
I have a question, do your hands still feel close together when you are typing on this?
I don't want to have to angle my elbows inward too much
