Author Topic: Configure YMD60  (Read 3651 times)
Offline marshskitow
Configure YMD60
« on: Mon, 23 November 2020, 16:43:44 »
Hello,
i spent about an hour to find on internet a way to do the layout i want but there is nothing to do, i beging to have doubt if it's possible.
I have a YD60MQ, and i want to do that layout :
256394-0
According to aliexpress it's possible, but when i'm doing the keymap i'm can only do this layout :
256396-1
So my only problem is the R shift and UP key. Can someone help me please ? Ty it's drinving me nuts ahah  :eek:
« Last Edit: Mon, 23 November 2020, 16:48:34 by marshskitow »
Re: Configure YMD60
« Reply #1 on: Mon, 23 November 2020, 17:52:19 »
You mean, you did that keymap in QMK Configurator?
If so, then my hunch is that the keymap that you have made should work. A keyboard configurator could have extra key positions that you don't have to populate with switches - and that is fine.
Do build your keyboard, flash it and try it out!
« Last Edit: Mon, 23 November 2020, 18:37:09 by Findecanor »
Offline marshskitow
Re: Configure YMD60
« Reply #2 on: Tue, 24 November 2020, 03:01:05 »
I already built it, i just changed my mind and change the YXCV row to get arrows on it.
But i have solder thinking it was fine.
I did the hex file with something else than qmk configurator. But your call is that it should work right ?
Envoyé de mon iPhone en utilisant Tapatalk
Offline marshskitow
Re: Configure YMD60
« Reply #3 on: Tue, 24 November 2020, 16:41:40 »
Okay, i figured out the problem. It was a solering issue or eventually a broken switch.
Thank you for your answeer, i was affraid that i was spending hours to do something impossible.
Let you have a picture of this weird build that i did, one of my first.
256469-0
