Author Topic: Uhhhh cherry g80-1800 help  (Read 1658 times)
Offline Error213
« on: Tue, 24 November 2020, 11:06:07 »
I’m looking into vintage blacks and I’m seeing so many cherry g80-1800s it’s almost feels too good to be true, I just googled it and there were ones on Amazon, bandh, and other places. I even checked on the deskthority wiki and it looked good to me. Just clarifying if I’ll actually get vint blacks from those keebs
Offline Prelim
Re: Uhhhh cherry g80-1800 help
« Reply #1 on: Tue, 24 November 2020, 11:15:17 »
from 1800 winkeyless you might get vintage blacks (even though you should have to look into pre-93 boards). from regular winkey 1800 you WONT get vintage blacks.
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline yui
« Reply #2 on: Wed, 25 November 2020, 01:23:15 »
too lazy to actually check but i think the g80-1800 is still made so it depend on the year but vintage blacks only were important until Cherry retooled now their new molds are as good as vintage, just do not want the ones from 95 to 2019 :) so i would not bother too much about it but then you do you
