Author Topic: Single Keycap Set Production  (Read 5108 times)
Offline IzzyG
« on: Tue, 24 November 2020, 21:58:51 »
Is it possible to create a custom keycap set and only have one of it made? For example get a single gmk set made? Thanks for any help :D
Re: Single Keycap Set Production
« Reply #1 on: Tue, 24 November 2020, 23:12:04 »
wasdkeyboards and that's it
unless you wanna shell out a grand for an SP set (if they still do that)
Offline IzzyG
« Reply #2 on: Tue, 24 November 2020, 23:53:06 »
Ok, thanks. As far as I can see, WASDKeyboards quality isn't great. What is SP?
Offline Nuclear Nachos
  • Anima and Animus
« Reply #3 on: Tue, 24 November 2020, 23:57:06 »
Signature Plastics https://www.solutionsinplastic.com/ They run SA and DSA profile, and maybe another that i cant remember  :)
Offline yui
« Reply #4 on: Wed, 25 November 2020, 02:16:23 »
i think pretty much all custom keycap manufacturer will do it just need to pay up the engineering and set up prices then they will do whatever you want but there is a reason why group buys have MOQ, those fees are extremely expensive and so you use GB to share them across many peoples making them more manageable.
Offline moxie keyboards
« Reply #5 on: Fri, 11 December 2020, 16:32:15 »
I think SP is $750 for the setup fee and no MOQ.
