Author Topic: [WTB] PCB design & prototyping service  (Read 6350 times)
Offline Riba
  • Trade Count: (0)
« on: Wed, 25 November 2020, 05:07:06 »
Hello all,
I am looking for someone who can design and (ideally) provide a limited number of working physical PCBs. All leads I found or had led nowhere, hopefully it will be different this time around. :-/
The layout is nothing fancy, 65% ortholinear, there are no deadlines (within reasonable time frame of course :))
Offline nevin
  • Trade Count: (0)
Re: [WTB] PCB design & prototyping service
« Reply #1 on: Wed, 25 November 2020, 10:55:23 »
possibly... Boardwalk PCB?
tons of layout options https://imgur.com/a/wGKjWd9
Offline Riba
  • Trade Count: (0)
« Reply #2 on: Wed, 25 November 2020, 10:57:33 »
Exactly, I need a Boardwalk but with one extra column. (65%, Boardwalk is 60%).
Offline nevin
  • Trade Count: (0)
« Reply #3 on: Wed, 25 November 2020, 11:37:04 »
what layout are you intending to use? on boardwalk you can get up to 70keys. you want dedicated home, end, pgup/dn? (just throw them on a layer)?
XD75 then? 5x15
the whole percentage thing falls apart when you're talking about ortho boards. when talking about ortho, it's easier to refer to the grid... 5x15 = 5 rows, 15 columns. or split orthos are usually only indicated as one half the full grid. split 5x6s = 5x12 grid
256532-0
Offline Riba
  • Trade Count: (0)
« Reply #4 on: Wed, 25 November 2020, 11:41:01 »
Apologies, I understand the confusion. It needs to fit a 65% case, so there are 16 1U columns. Here is the layout.
Offline nevin
  • Trade Count: (0)
« Reply #5 on: Wed, 25 November 2020, 11:53:42 »
at that point. you're probably better off getting a plate cut in this layout and handwiring.
it's not terribly difficult, and there's a lot less to mess up then fabbing a pcb.
i'm currently playing around with an ergo layout in KLE that doesn't exist yet either.
there's also the BFO-9000 from keeb.io if you wanted to go split.
« Last Edit: Wed, 25 November 2020, 11:57:13 by nevin »
Offline Riba
  • Trade Count: (0)
« Reply #6 on: Wed, 25 November 2020, 12:12:51 »
Yes, already have a plate and I might go the handwiring route until (if ever) I get the PCB done. I actually started doing it myself but at the moment time is more precious commodity than money, and at this rate it will be completed a little after never. Never thought it would be this hard to find someone to tackle this project.
« Last Edit: Wed, 25 November 2020, 12:14:49 by Riba »
Offline nevin
  • Trade Count: (0)
« Reply #7 on: Wed, 25 November 2020, 12:43:41 »
most of the guys i know that do pcb work have a huge backlog of projects/commissions.
if you need a hand with the handwire let me know, i can help with firmware & such. just finished helping another forum member do their 1st handwire.
good luck on the hunt.
Offline Riba
  • Trade Count: (0)
« Reply #8 on: Wed, 25 November 2020, 13:01:06 »
Thanks for offering the hand, it is much appreciated! I will PM you when and if the time comes!
Offline Netdewt
  • Trade Count: (0)
  • OLKB
« Reply #9 on: Thu, 10 December 2020, 15:55:07 »
I have looked for this size also. It would allow a full numpad and +-*/= keys.
The XD 75 could work without the math keys, but I have not read good reviews about its fit into existing 60% cases.
I want to learn PCB design, but not there yet...
