Author Topic: Unknown old keyboard  (Read 3382 times)
Offline Evol
« on: Thu, 26 November 2020, 11:33:24 »
Hi there !
I'm currenty looking to old mechanical keyboard to restore, and I found this one.
The problem is, I can't find information about it, and therefore can't know if it's a mechanical, or if it's a good quality keyboard.
Thank you :)
Re: Unknown old keyboard
« Reply #1 on: Thu, 26 November 2020, 16:42:30 »
It is hard to see, but to me it looks like a single keycap profile on a curved backplane. Those are seldom mechanical.
There is often a FCC ID. From that you can look up the manufacturer.
Offline yui
« Reply #2 on: Fri, 27 November 2020, 01:40:52 »
aren't NBKs dome with sliders? i may have the letters in the wrong order, or even the wrong letters but if i am right those are considered pretty good dome with sliders boards. depending on your definition of mechanical keyboards those most definitely are in or out of it :)
with some of those keyboards the caps are easy to pull out (and looks like on yours some have been replaced so likely in that camp) if you can pull one you will be sure of that it is
Offline Evol
« Reply #3 on: Fri, 27 November 2020, 03:52:37 »
Thank you for your help !
Well I found all the informations I needed with the patent numbers, I didn't expect to have so quick and good results from such an old product :)
@yui not sure what is domes with sliders exactly , but looks like it :) right ?
« Last Edit: Fri, 27 November 2020, 03:54:42 by Evol »
Offline yui
« Reply #4 on: Fri, 27 November 2020, 04:01:00 »
well exactly that :)
