Author Topic: Milling your own plates  (Read 1934 times)
Offline TomahawkLabs
« on: Fri, 04 December 2020, 08:58:11 »
I and currently building my CNC (finally got time after these home updates got done) and my goal was to create a full size and TKL + Numpad Apple M3501. I plan on handwiring the first few boards while I learn KiCAD and hopefully would like to create a blank PCB that can have a teensy soldered on rather than a production board.
Does anyone create their own CNC and build their own custom or prototype boards? If so, what tools do you use to design/create the plates? My Thought was to create plates 100% in Fusion360 and use that as the CAD and CAM program.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Atomical
Re: Milling your own plates
« Reply #1 on: Mon, 07 December 2020, 00:34:20 »
Fusion 360 is good, there's lots of tutorials online that will help you out. And it has built in CAM software that will allow you to export tool paths and g-code to your cnc milling machine.
