Author Topic: Corsair K95 key not working, switch OK  (Read 7808 times)
Offline SolfDoernplop
« on: Mon, 07 December 2020, 04:13:22 »
I have a Corsair K95 LED monochrome mechanical keyboard with red switches and have the strangest defect that I can't fix.
I spilled a tiny little bit of water on it. I dried it, cleaned it, but the space key does not work anymore, no matter what I do. It is just the space key, all other keys work. I took the keyboard apart and found that the switch actually works (checked with a multi meter)
What could this be? That just one key does not work? Any suggestions how to fix this?
I don't want to throw away the keyboard just for one single key, but I need the space key.
Possible workaround?:
I figured if I could wire the space key switch to another key (like right alt or the context key (left of the right Ctrl key. I definitely never use that key) and then remap that key to space in the keyboard layout, it could make it work.
What are your thoughts about it?
Re: Corsair K95 key not working, switch OK
« Reply #1 on: Mon, 07 December 2020, 06:42:09 »
If somehow during cleaning you damaged the trace to that switch you should be able to solder a jumper wire to reconnect it properly.
Also have you checked the diode connected to that switch (if there is one) - It should have continuity one way but not when you swap the probes.
Post picture of the area around that switch, if the PCB is black or white you'll need to get the traces to show up in the shine (hopefully it's not as this is not fun!)
« Reply #2 on: Mon, 07 December 2020, 13:46:59 »
I most definitely did not hurt any traces, I work with electronics a lot and I was super gentle. The only thing that could have happened was that the liquid damaged something like the diode (why do you need a diode?), will check that, there are these tiny little component and every key has one.
What about redirecting the key? Does anybody know if that works? I have a few keys on the keyboard that I never use. I figure I can just solder leads to the space key and connect that to the other key and then remap space on that key.
« Reply #3 on: Mon, 07 December 2020, 14:45:13 »
The diodes are there to stop the controller getting confused when you press multiple keys at the same time.
You could desolder the space switch and insulate the pins from the PCB then solder both pins to another switch and remap the other key in software but 99% sure you have somehow killed the diode and replacing it will bring the switch back.
Whatever has happened you have not killed either of the pins space is (should be) connected to so you can make it work good as new.
« Reply #4 on: Mon, 07 December 2020, 19:57:18 »
I can check out the diode. Why would I need to desolder the key? it is not connected right now as it is, I could just wire it to another key I figure.
« Reply #5 on: Tue, 08 December 2020, 00:24:39 »
It is probably half connected, connecting two places into one will result in two keys being pressed.
If the board was wired friendlily like a DIY one you could connect two rows or columns (depending which way the diodes are connected) so pressing B or . could type both.  If you posted a pic I'd (hopefully) add some dots and suggest places to connect but it seems a requirement for designing keyboard PCBs professionally is to be an addict as they are rarely as sensible or organised as those first timers here create.
Search for'switch matrix if you're interesed :)
« Reply #6 on: Mon, 01 February 2021, 16:08:08 »
I will make a picture of the PCB, there seem to be no diodes, the multimeter does not show what looks like diodes are actually diodes.
I don't have much experience with keyboards, but wow, next time I buy one, i will definitely shun corsair and never buy a keyboard from them again, they are too expensive to not be repairable and such a pain in the butt to fix.
Offline yui
« Reply #7 on: Tue, 02 February 2021, 06:47:08 »
if it is in series with the switch you can always try to short that diode-not-diode and see if your space start working again before starting rerouting keys, in circuit diodes can behave strangely to being tested, especially if damaged, and yeah pics would help
« Reply #8 on: Mon, 22 February 2021, 18:02:35 »
Here is a picture of the board, the black circle is around the switch that is relevant (space key). This is a LED keyboard (not RGB), with one LED per key backlighting.
I'm curious what you guys make of this PCB, what the little thing is that looks like a Diode.
« Last Edit: Mon, 22 February 2021, 21:57:38 by SolfDoernplop »
« Reply #9 on: Mon, 22 February 2021, 18:27:02 »
It's a nice colour and at least semi sane :eek:  This is actually one of the best looking commercial PCBs I've seen for repairing with visible traces and diodes not attached at random (at least in this bit...)
The thing that looks like a diode is indeed a diode, it should only allow current to flow one way so on a multimeter it should continuity beep with the probes one way round but not the other.
Or the brute force test without a multimeter is shorting purple to green to bypass the switch and diode, if that types a space the diode is dead and needs replacing.
262819-0
« Reply #10 on: Fri, 26 February 2021, 16:30:50 »
Thanks for the instructions. I connected the two points with a lead and nothing happens, no space gets typed. I remember having tested the diode and I think it was fine, otherwise I would have immediately thought of the solution to replace it. So I don't know what the hell is going on here, but something else is broken.
« Reply #11 on: Sat, 27 February 2021, 06:29:33 »
OK, must be the other pin.  Diodes go up and there's a row of vias going across the bottom attached to the non diode pins so red to green should type a space, if it does solder a wire between red and purple and it's fixed.
263153-0
« Reply #12 on: Sat, 27 February 2021, 07:27:01 »
YES, this actually works, this does type a space. Now what do I have to solder to what? I guess I'm kinda unclear why this position on the left (where there is a position for a switch to be soldered in, but there is actually nothing) plays into the space switch.
I'm not in the know how traces get wired around a PCB.
Do I have to get another diode?
« Reply #13 on: Sat, 27 February 2021, 11:04:40 »
Haha, keyboards are like the 'magic' that wows children but is really easy once you know how it works.  The switches are connected in a grid so that (for example) you can have 64 switches using only 16 pins (8x8 grid) on the controller rather than needing a pin for each switch.  There is a trace on the other side of the PCB connecting the little dots (vias) connected above the red and purple pads, usually breaking this trace would take out all the switches left or right of the break depending where the controller chip is, it's even more impressive/confusing when a single wire brings a whole block of keys back.
As above - if red to green types a space solder a wire between red and purple and the switch will be reconnected where it should be, as long as the diode is alive (no reason it shouldn't be) it will work good as new.
« Last Edit: Sat, 27 February 2021, 11:13:27 by suicidal_orange »
« Reply #14 on: Mon, 01 March 2021, 12:34:13 »
I will get soldering and see if that fixes it. Curious if I can revive this keyboard, it has now been out of order for years.
« Reply #15 on: Sun, 14 March 2021, 23:59:18 »
I did work, thank you so much! I can now finally use the keyboard again, after so many years of it sitting around unfixed. The space key is very important,  don't know why it broken. I love having a nice mechanical keyboard instead of a piece of crap cheapo one.
« Reply #16 on: Wed, 17 March 2021, 16:46:32 »
I'm happy clicky di clacky all days long, a mechanical keyboard is so much better for typing fast and furious, it sounds like the intensive post you are punching in.
When gaming, it lends the sound to desperate or intense movements of WASD, it is just a symphony to my computer scientist's ears.
« Reply #17 on: Thu, 18 March 2021, 00:27:03 »
Glad you got it working and are enjoying the extra noise we all love :)
