Author Topic: Dierya DK61E - Find out which Board its using and firmware export!  (Read 4258 times)
Offline Noxiousnada
« on: Mon, 07 December 2020, 15:27:25 »
So i got the Dierya DK61E and i want to customize the RGB because the software dosent covers any options for customizing the RGB.
So far i found out that the boarddescription is: EPC-GK01U201
but i dont find any informations about the used firmware/Microcontroller that i can customize that firmware/the RGB.
Maybe u have any sugegstions
Peace
« Last Edit: Mon, 07 December 2020, 16:08:13 by Noxiousnada »
Offline Darthbaggins
  • PC Cannibal
Re: Dierya GK61E - Find out which Board its using and firmware export!
« Reply #1 on: Mon, 07 December 2020, 15:42:52 »
only thing I can find is the DK61E not the GK61, but found the website/store which has the software for the boards  :thumb:
https://kemove.com/c/mechanical-keyboard-0378
Offline Noxiousnada
« Reply #2 on: Mon, 07 December 2020, 16:09:51 »
oops, i mean the DK61E, my bad!
so i know that they use the same boards like KEMOVE, but u cant find anything which board they use and which microcontroller.
is there a way to get the firmware?
peace
