Author Topic: Switches that Support Top Internal SMD RGB LEDs?  (Read 1692 times)
Offline King Icewind
    • Keys of Kings
« on: Tue, 08 December 2020, 15:57:48 »
I know the Cherry MX RGB variants will support an internal SMD RGB LED like the LTST-C19HE1WT. Do other RGB variant switches also support this by default? I'm not sure.
I am working on a microcontroller board that utilizes an M.2 connector to plug into the keyboard PCB. It's a cozy fit but functional. The only issue is that it doesn't easily support the gull wing/4-PLCC bottom mount type RGB LEDs... So, if there is only a few switches that support the top internal mount RGBs then I may need to take the project in a different direction.
Thank you,
King Icewind
« Last Edit: Tue, 08 December 2020, 16:04:08 by King Icewind »
