Author Topic: Repeating Key Presses  (Read 2107 times)
Offline ducky8787
« on: Wed, 09 December 2020, 12:03:52 »
Hey guys,
I have come across a predicament. In a game I play I press two buttons at once and the game registers EQQQQQQ for example. I know some keyboards would send an alternating EQEQEQ instead. The second would be really advantageous to me as I wouldn't need to time everything perfectly anymore. Is there any way to modify my keyboard firmware to register an alternating pattern when two keys are pressed at the same time? I read that someone can do this using an auto-repeater but I don't think it works with my keyboard. If not, is there a way to do this using macros?
I have a Ducky One 2 Mini.
Offline 1391406
Re: Repeating Key Presses
« Reply #1 on: Wed, 09 December 2020, 12:25:40 »
Try AutoHotkey.
Offline ducky8787
« Reply #2 on: Wed, 09 December 2020, 12:31:45 »
Thanks for the reply. I am trying it right now I just can't seem to figure out a way to implement it so that if I press E and Q at the same time I get a repeating output for the length of time I hold down E and Q.
Offline 1391406
« Reply #3 on: Wed, 09 December 2020, 13:18:32 »
I'm not proficient enough with AutoHotkey to know whether it can do what you're asking.
Offline ducky8787
« Reply #4 on: Wed, 09 December 2020, 13:25:37 »
So I just discovered something. If I press Q and E at the exact same time (probably within 10ms) I get the EQEQEQ repeating pattern. But when I press one before the other I get the EQQQQ or QEEEE pattern...
