Author Topic: FC980C rattling spacebar  (Read 2856 times)
Offline NickPham
« on: Thu, 10 December 2020, 00:32:51 »
Hi guys, my FC980C has a big problem with spacebar (PBT spacebar), it's rattling from all side (left, right, middle). The sound is so off comparing to other keys, it sounds tick-tick, no more 'thocking' sound :(. Guess that I have to disassemble to lube the stab but it still has 1-year warranty so is there anyway to fix it without voiding warranty? :(
If disassembling is the only option, I don't know how to do it, never done this before :(
Sound video:
https://www.youtube.com/watch?v=lC2COYIq0P0
https://www.youtube.com/watch?v=cyvTKc2hlps
Offline Sup
Re: FC980C rattling spacebar
« Reply #1 on: Thu, 10 December 2020, 07:21:57 »
Get some superlube in  the stabilizers and your sound will be muted again like before. I assume it normally came with a ABS space bar otherwise it could be that the pbt space-bar is warped.
current
Coming soon
Offline NickPham
« Reply #2 on: Thu, 10 December 2020, 08:36:28 »
I've tested with ABS spacebar and rattling still happens...
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Thu, 10 December 2020, 08:40:35 »
Sounds like the wire popped out of one of the hooks on the housings that hold it in place. You can usually get a precision flathead screwdriver in between the plate & stab housing to force it back into it's clip.
Offline Polymer
« Reply #4 on: Thu, 10 December 2020, 11:19:41 »
I actually think a warped spacebar fixes this problem...
