Author Topic: [IC] GMK Seafarer | GB Live!  (Read 175309 times)
Offline iinko_mk
  • Status: broke
« on: Sat, 12 December 2020, 20:23:39 »
Discord if you'd like to join
GMK Seafarer
"Master of the seven seas"
Inspiration
The original colorway was inspired by the uniforms of our Navy sailors on the high seas, and with novelties inspired by sailing and navigation.
Why?
I love minimal sets, LOVE blue, and have always been fascinated with
everything about sailing and the sea but could not really find a nice set
that would fit my requirements, so here we are.
Colors
Kits/Renders
Please note that renders do not always accurately show what the set will look like. Please take this into
consideration as different people’s monitors are different, and hex codes are not always correct.
Lighting also is a huge factor when it comes to rendering. Please consider looking at the base kit for the most accurate render.
The Captain's Kit - $125 USD
Supports terminal ISO, 1800, Tsangan, HHKB, and most 96%.
The Quartermaster's Kit - $47 USD
Anchor, Wheel, Northstar, Flags, Compass, Waves, Northstar(1.25u), Map
The Sailor's Kit - $30 USD
6u centered + off centered, 6.25u, 7u, 2.75u, 2.25u, 2u, 1.25u
Adventurers Kit - $37 USD
Deskmats
Deskmats Specs:
900mmx400mm Size
4mm Thickness
Cloth Surface
Rubber Bottom
Hand Washable
Anchored
Mapped
Renders
F1-8X by Geon Works
Haus by Hand
i69 by Illuminati Works
Maja by Vulcan x KBDFans
OG TKL by Oggi
SP111 by BlindAssassin
Ribbon40
Vendors
US - Mechs N Co
CA - AshKeebs
EU - MyKeyboard.EU
CHINA - KBDFans
SEA - Ilumkb
OCE - Daily Clack
Korea - Monstargears
Collabs
Custom Cables - SpaceCables
Metal Artisans - THOK
Blue powdercoat with white enamel fill
Artisans - Fraktal, Latrialum
(Images Coming Soon)
GB Info
GB will go live on April 16th and end on May 16th
Pricing
HUGE THANKS TO:
    • AllieBlairThomas for being there at the beginning and being the light along the dark path. And the first person to actually give a ****.
    • Konstantin, Tom, and LP for their great help with novelties
    • Konstantin for his great help with kitting
    • Swishy, Bunneh, Grumpy, Shenshen, Oggi, and Bachoo for renders and rendering help
    • Nathan for teaching me the basics of UV
    • Koosha(Ram), Shiba, Allie, Jimmy, Dworfy, Swishy, Grumpy, Oggi, and Shenshen for just being the real ones and supporting me in VC all the time.
    • LP for the wonderful name of Seafarer
Changelog
4/2 - Pricing announced and FraktalKap revealed
3/10 - Finalized kitting and new labels
3/5 - Thok Artisan and GB date announced
2/18 - Added 40s and more accurate kit renders
2/11 - Fully Revamped Renders
12/15 - Vendors Announced, Metal Artisan, Cable
12/17 - Minor Kit Changes, Some artisans
1/5 - Added Topo Deskmat
Signature
Please consider supporting my set by adding this signature!
[/list]
Code: [Select]
[url=https://geekhack.org/index.php?topic=110169.0][img]https://i.imgur.com/Kjpycvs.png[/img][/url]
« Last Edit: Sun, 29 March 2026, 18:11:59 by iinko_mk »
Offline halocantkb
  • Formerly 'shota_irl'
Re: [IC] GMK Seafarer
« Reply #1 on: Sat, 12 December 2020, 20:23:50 »
this is sick
« Reply #2 on: Sat, 12 December 2020, 20:23:57 »
IINKO THIS SET IS AMAZING YOUR AMAZING I'M SO PROUD OF YOU
Offline iinko_mk
  • Status: broke
« Reply #3 on: Sat, 12 December 2020, 20:24:03 »
finally did it
« Last Edit: Sat, 12 December 2020, 20:31:17 by iinko_mk »
Offline hark
« Reply #4 on: Sat, 12 December 2020, 20:24:07 »
Reserved
Jokes aside this is hype
glwic :)
« Last Edit: Sat, 12 December 2020, 20:31:16 by hark »
Offline RIFT
    • RiftKeys
« Reply #5 on: Sat, 12 December 2020, 20:24:11 »
Ahoy Matey
Offline darthcapn
« Reply #6 on: Sat, 12 December 2020, 20:25:24 »
Looks awesome, any chance for a color flipped kit too? That'd be too hot!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline konstantin
  • Formerly constexpr
« Reply #7 on: Sat, 12 December 2020, 20:27:20 »
Code bad; please consider System or Super :) Other than that, really nice kits. And awesome novelties!
Edit: It looks like you're missing a second 2.25u Shift in the base kit (there's a 2u instead). You might want to fix this if you're going for comprehensive coverage. Also — and this is optional — 1c keys would be a nice addition to the spacebars kit.
Edit2: If it helps, you can probably drop 00 from the base kit.
« Last Edit: Sat, 12 December 2020, 20:33:22 by konstantin »
Offline Litomymu
« Reply #8 on: Sat, 12 December 2020, 20:28:24 »
The madman did it, can't wait to see this set made real. GL!
Offline Ireojimayo
  • Yo dayo
« Reply #9 on: Sat, 12 December 2020, 20:29:37 »
AHOY!
Offline Ram
« Reply #10 on: Sat, 12 December 2020, 20:31:43 »
POG
Offline iinko_mk
  • Status: broke
« Reply #11 on: Sat, 12 December 2020, 20:35:29 »
It is a 2.25u shift, just the render is incorrect, i'll look into it.
Offline HungHingDaiLo
  • 無間道
« Reply #12 on: Sat, 12 December 2020, 20:36:29 »
+1, agree with these! GLWIC!
IG: @rayhhdailo
Offline totalemon
  • good morning :)
« Reply #13 on: Sat, 12 December 2020, 20:39:49 »
I feel like this would really benefit from a colour-swapped alphas kit. The novelties and banner are sick !!
Offline Mootook
« Reply #14 on: Sat, 12 December 2020, 20:59:02 »
^ ditto. I love these colors, though I'd also like to see swapped alphas as a secondary kit.
Offline Atomical
« Reply #15 on: Sat, 12 December 2020, 21:16:27 »
I’ve been looking for a color combo this beautiful for a while. I’m in!
Offline Dazon
« Reply #16 on: Sat, 12 December 2020, 21:21:59 »
hot damn, those novelties are so beautifully simple in a way that gets the point across while still keeping them looking great. glwic!
Offline iinko_mk
  • Status: broke
« Reply #17 on: Sat, 12 December 2020, 21:22:20 »
I'm changing it to super.
Offline Kinesiologist
« Reply #18 on: Sat, 12 December 2020, 21:25:29 »
Looks great and +1 for keeping it minimalistic. It is possible to add an F13 in the base kit?
« Last Edit: Sat, 12 December 2020, 21:52:06 by Kinesiologist »
Offline powwu
    • Discord
« Reply #19 on: Sat, 12 December 2020, 21:38:31 »
clean. kitting looks a bit lacking, wheres f13 and B? otherwise, glwic
Offline misswaffle
« Reply #20 on: Sat, 12 December 2020, 21:41:45 »
Set looks great, and I love the simplicity! A reversed coloured mod kit would be nice to see.
Offline kk73715
  • Why are you even reading
« Reply #21 on: Sat, 12 December 2020, 21:50:26 »
love the colors! set looks so simple yet so good
- I like the numpad in base kit
- I like two escapes, the two enters, and the two arrow sets
- I like iso support
- can one of the backslashes be removed?
- add 2nd 'b' in base kit?
- add F13 key in base kit?
- chance for R5 bottom row?
- change text mods to icon mods?
glwic :)
Offline GrimmOmen
« Reply #22 on: Sat, 12 December 2020, 21:51:25 »
Very clean. Keys look great.
This 10000% needs a Fraktal collab. Maybe with a brass anchor.
I'd be interested in how colored mods look.
Offline iinko_mk
  • Status: broke
« Reply #23 on: Sat, 12 December 2020, 21:55:35 »
since people are asking, i will be including a f13 and a "B" in the base kit. will update soon
Offline ogp3
« Reply #24 on: Sat, 12 December 2020, 21:57:27 »
Oooh this is super cute - love these novelties and the theme. Any chance of a 40s kit?  :D
Offline Shironome
« Reply #25 on: Sat, 12 December 2020, 22:06:15 »
It's so cute... I want it.
Offline FaIIen
« Reply #26 on: Sat, 12 December 2020, 22:20:42 »
Nice job! Very clean, very interested :))
Offline konstantin
« Reply #27 on: Sat, 12 December 2020, 22:31:28 »
Adding F13 is fine, it's more useful than 00 anyway. +1
There is no need to add a second B to the base kit. Do people even stop to look before they ask this, lol? All of the spacekeys required for Alice layouts are in the spacebars kit, so that's where the B should stay. (If you're looking to use the set on an Alice board without getting the spacebars kit, you can use numpad 0 together with Shift keys, as per usual.)
Including the second B in base only truly makes sense when spacekeys are offered in two different child kits (e.g. spacebars and 40s). In that case, having the key in base allows buyers to choose which of the two kits they want to get. On the other hand, when there is only a single kit containing spacekeys, there is no such benefit to having B in base, and the pricing difference that it makes to the spacebars kit isn't at all significant from what I've seen.
Which & why?
« Last Edit: Sat, 12 December 2020, 23:25:18 by konstantin »
Offline powwu
    • Discord
« Reply #28 on: Sat, 12 December 2020, 22:34:20 »
There is no need to add a second B to the base kit. Do people even stop to look before they ask this, lol? All of the spacekeys required for Alice layouts are in the spacebars kit, so that's where the B should stay. (If you're looking to use the set on an Alice board without getting the spacebars kit, you can use the numpad 0 together with Shifts, as per usual.)
Including the second B in base really only makes sense when spacekeys are offered in two different kits (e.g. spacebars and 40s). The pricing difference that it makes when there is a single kit isn't at all significant.
What, why?
You quoted the wrong person, this makes me look bad. I never asked for a slash to be removed
Offline konstantin
« Reply #29 on: Sat, 12 December 2020, 22:36:43 »
My apologies. Copy-paste error. Fixed now :thumb:
Offline Owl
« Reply #30 on: Sat, 12 December 2020, 23:05:56 »
Simple clean and classy. Very well done! Kitting, colors, and deskmat have such a great polish to them. Good luck with IC and GB!
Offline SMOKEY
« Reply #31 on: Sun, 13 December 2020, 03:29:57 »
FINALLY!
Thank you so much for this awesome set!
Absolute instabuy! I adore the novelties so much.
Offline SleepyHako
« Reply #32 on: Sun, 13 December 2020, 07:37:15 »
YES!
How about a navy Rama cap with a North Star white in fill?
Offline deathman28
« Reply #33 on: Sun, 13 December 2020, 08:11:40 »
I absolutely love this set, would work great with my navy satisfaction 75!
Offline iinko_mk
  • Status: broke
« Reply #34 on: Sun, 13 December 2020, 10:33:35 »
YES!
shh....
Offline ManoliVisuals
« Reply #35 on: Sun, 13 December 2020, 11:31:29 »
Absolutely love how clean this set is
Offline SirKhamenman
« Reply #36 on: Sun, 13 December 2020, 15:32:38 »
Like many has said, I like how clean it looks, and how well it matches with e-white keyboard! Since I have a GB e-white Vega, this looks like the matching keycaps for me. I'm in 100%
Offline treeleaf64
    • treeleaf64
« Reply #37 on: Sun, 13 December 2020, 15:54:44 »
Looks ok but you do not have Norde UK support /in the kitting
Everyone must pay the cat tax
Offline YouGotRioted
Re: [IC] GMK Seafarer | Changes Inbound!
« Reply #38 on: Sun, 13 December 2020, 19:13:36 »
This would perfectly colour match the Cloud White Satisfaction75 (and thematically too)
Offline StingrayShuffle
« Reply #39 on: Sun, 13 December 2020, 20:17:09 »
Great work. Very clean set! Looking forward to it.
Offline atlanticise
« Reply #40 on: Sun, 13 December 2020, 20:29:07 »
This is so cute! Your Captain's Kit image is broken I think!
Offline trung11.kb
  • Formerly tomkatsuuu
« Reply #41 on: Sun, 13 December 2020, 21:31:34 »
Reserved! Good luck man, but I still think you should've named it "GMK Se(a)men".
Offline ThickJimmy
« Reply #42 on: Sun, 13 December 2020, 22:02:05 »
Great job, Inko. Really love the set!
Offline adxlk
« Reply #43 on: Sun, 13 December 2020, 23:46:53 »
Hello, are you thinking of doing more deskmats? If so, do you want to collab?
Offline monstargear
    • Monstargear
« Reply #44 on: Sun, 13 December 2020, 23:48:28 »
Looks awesome!
Offline gilbert
« Reply #45 on: Mon, 14 December 2020, 04:59:40 »
looks really good, glwic
Offline iinko_mk
  • Status: broke
« Reply #46 on: Mon, 14 December 2020, 11:03:29 »
it should be working now!
Offline zoo
    • zoo
« Reply #47 on: Mon, 14 December 2020, 14:14:17 »
big want
Offline iinko_mk
  • Status: broke
« Reply #48 on: Mon, 14 December 2020, 14:23:14 »
thanks jimmy
Offline iinko_mk
  • Status: broke
« Reply #49 on: Tue, 15 December 2020, 10:28:32 »
Nice, would love to see that!
