Author Topic: Oh, the irony...  (Read 2385 times)
Offline ergonaut
Oh, the irony...
« on: Mon, 14 December 2020, 07:24:06 »
I just bought a new keyboard, an XD75. Initially, I'd thought about going with Kailh Box Silent switches. One of the reasons I eventually decided against those was the whole thing that Kailh Box switches might damage your keycaps. So I went with Gateron Silents instead. And now some of my keycaps fall off when I turn the board upside down  :eek:
Offline Kavik
Re: Oh, the irony...
« Reply #1 on: Mon, 14 December 2020, 16:03:54 »
Are your keycaps cracked, or are the Gateron stems just too small? Which keycaps are they (Cherry, SP, Tai Hao?)?
Offline yui
« Reply #2 on: Tue, 15 December 2020, 01:11:11 »
and the kailh box cracking thing was solved more than a year ago, no longer an issue... but yeah seems strange that your caps just fall off, i have gmk on gat silent reds and they are pretty tight
Offline ergonaut
« Reply #3 on: Tue, 15 December 2020, 03:30:04 »
As far as I can tell, they are not cracked. I don't really remember the brand, they're some cheapo caps I bought from Aliexpress a while back. Also, they were installed on my Kinesis before, which has Cherry MX browns. Maybe they are just a bit worn out now? I don't know.
Offline ergonaut
« Reply #4 on: Tue, 15 December 2020, 03:30:33 »
Good to know, thanks.
