Author Topic: New in Retail Box Model M - Selectric Touch by Easy Options  (Read 1800 times)
Offline Voixdelion
« on: Thu, 05 August 2010, 18:59:23 »
So the seller decided that it was too nice for personal use (maybe he'd look into a used one though) and re-listed this with all the appropriate yummy details for the folks like us who dig 'em... Depends how much noise on the channel for where it ends up, but starting bid is 0.99 + >17.00 S/H (and they've been instructed on proper packing to ensure its non-mangled arrival as well.)
Blue label with two piece key-caps comes with ps/2 (Female) to 5 pin DIN (Male) adapter in case you have a need for one:
NIB 60G3571 -Made by Lexmark - 01 DEC 1994
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline Voixdelion
« Reply #1 on: Mon, 16 August 2010, 01:03:08 »
Didn't think anyone here was  interested - It would have gone even cheaper the first time around.  I actually helped the seller out a little with some info on what they had there.  If I hadn't JUST purchased a NIB M from Clickeykeyboards the week prior I would have been tickled to take it...
