Author Topic: Ramaworks Kara: Polycarb plate + hotswap ?  (Read 1822 times)
Offline guyga
« on: Fri, 25 December 2020, 17:25:42 »
The Kara comes with a PC plate and hotswap PCB. I've read that this is a bad combo because the PC plate is too flimsy/flexible and the switches can pop out (see this reddit thread about the tofu for example). Is this somehow not a problem for the Kara?
« Last Edit: Fri, 25 December 2020, 17:27:27 by guyga »
Offline Sup
Re: Ramaworks Kara: Polycarb plate + hotswap ?
« Reply #1 on: Fri, 25 December 2020, 18:33:32 »
Putting switches in a PC plate is harder then other stiffer plates. You probably have to disassemble and then put the switches in and fix when ever the switch doesn't want to go into the plate you push the plate from below so the switch clicks into place. Otherwise it just pushes the plate down because of how flexy it is.
I don't have any experience with hotswap since i only use solder though but this is my experience building with poly plates.
current
Coming soon
